ᐅ How can I properly clean BILLY shelves without damaging the surface?
Created on: 8 Mar 2024 09:17
Danyal9
Danyal9
8 Mar 2024 09:17
I have several Billy shelves from IKEA at home and want to clean them regularly without damaging the surface. I am particularly interested in how to properly care for the sensitive surface, which cleaning agents are suitable, and the best way to avoid scratches, peeling of the laminate, or dull spots.
Could you please share any tips on methods that have proven effective and whether there are specific products or home remedies that should be avoided?
Thank you in advance!
Domau0
8 Mar 2024 09:32
Hello Danyal9,
I would like to provide a more detailed explanation about cleaning BILLY shelves, as the commonly used laminated surface is sensitive to the wrong cleaning agents.
1. First of all: never use aggressive chemicals, solvents, or abrasive cleaners. These will quickly damage the surface and cause the laminate to swell or peel.
2. A mild water-based cleaner is ideal. For example, a very small amount of dishwashing liquid dissolved in warm water. Use a soft microfiber cloth, not any rough material.
3. Wipe the shelf first with a dry cloth to remove dust. Then use a damp cloth to gently wipe the surfaces. Important: do not work with too much water to prevent moisture from getting into the edges or joints.
4. For drying, it is best to use a dry, soft cotton cloth. This helps avoid water spots.
Finally, a note: for stubborn stains, you can apply 70% isopropanol lightly to a cloth and rub the stain gently, but be very careful as it may damage the laminate. Always test first on an inconspicuous spot.
May I ask what kind of floor or surface your shelf stands on (including room climate and humidity), as this also affects durability? And do you use the shelves heavily, for example in an entryway or office, or mostly for decorative purposes?
ju_ren
8 Mar 2024 09:45
I simply use a slightly damp microfiber cloth without any cleaning agents to wipe the shelf. Occasionally, I follow up with some soapy water. Do not use harsh cleaners, as they can damage the surface.
tra_nina
8 Mar 2024 10:12
For proper cleaning of BILLY shelves, please note that the surface is usually made of coated particleboard. Therefore, mechanical stress should be minimized.
Recommended cleaning methods include:
- Removing dust with a dry cloth or duster
- Wiping with a damp cloth and a mild, pH-neutral cleaning agent
- Using soft cloths to avoid scratches
- Avoiding solvents or alcohol unless spot cleaning is necessary
Please ensure that no water seeps into the edges to prevent swelling.
LOGEMIN
8 Mar 2024 11:07
Hello Danyal9,
here is a brief guide for properly cleaning the BILLY shelves:
1. First, remove all items from the shelves.
2. Use a dry microfiber cloth to remove dust and loose dirt. Alternatively, a vacuum cleaner with a brush attachment can be used for more effective cleaning.
3. For regular cleaning, prepare a solution of lukewarm water with a few drops of mild dish soap. Do not soak – the cloth should be damp, not wet.
4. Gently wipe the surfaces, always following the direction of the laminate grain.
5. Never scrub or use abrasive sponges, as this can dull the surface or cause scratches.
6. Finally, dry the surfaces with a dry cloth to prevent moisture from absorbing.
Common mistakes include using too much water, harsh cleaners, abrasive sponges, and alcohol, all of which can damage the surface.
If stains are stubborn, a glass cleaner can be used for spot cleaning – but please dilute it heavily and always test it first on an inconspicuous area.
Hope this helps you!
BOMILAN
8 Mar 2024 11:59
Clean only with a damp cloth and mild soapy water, then wipe dry. Do not use harsh cleaners, as they can cause scratches or dull spots.
