ᐅ How can BILLY shelves be cleaned without damaging the surface?
Created on: 26 Jan 2024 09:12
pupa60
some time ago, I bought several Billy bookcases from IKEA and really appreciate their flexibility and design. Now I am facing the challenge of how to properly clean these shelves without damaging the surface.
The shelves have a rather matte, laminated finish, which in my opinion is sensitive to moisture and harsh cleaning agents. I want to avoid stains, rough spots, or shiny areas forming after cleaning.
I am interested to hear which cleaning methods have proven effective within the community, whether simple household remedies are sufficient, or if special products are recommended. Are there any tips on how to handle damp cloths, or how to better deal with dust and stubborn dirt?
I look forward to your experiences and advice. Thanks in advance!
pupa60
26 Jan 2024 16:19
Joe52 schrieb:
@pupa60: Have you already tried something, and if so, what was the result?
Thank you for asking! So far, I have only wiped the shelf with a standard all-purpose cleaner, which was not ideal. The surface appeared somewhat dull in certain areas afterwards, and small spots or water marks formed that I couldn’t remove immediately.
Because of this, I have become more cautious and am looking for gentler cleaning methods. In daily use, I usually just dry dust, but that does not address the issue with stubborn dirt particles.
I find especially the tips about using mild dish soap and drying immediately interesting. Perhaps that is a good compromise.
anken
27 Jan 2024 08:03
From a professional perspective, I recommend paying special attention to the following aspects when cleaning Billy shelves:
1. Use pH-neutral cleaning agents, as they are the least damaging to the surface.
2. Use cleaning agents sparingly, ideally only a few drops in water.
3. Avoid cleaning agents containing alcohol, acetone, or similar solvents.
4. Microfiber cloths should be clean to prevent scratches from foreign particles.
5. Always rinse with clear water after cleaning and dry immediately.
These are standard practices in industrial or craft applications that can also be effectively applied in private households.
Luciandi
27 Jan 2024 10:25
That makes sense – I’ve often made the mistake of just grabbing the first cleaner available.
I’m also curious: how do you handle corners or edges that are often more delicate than flat surfaces? Is a simple dust cloth enough, or should you be extra careful there?
tutan
27 Jan 2024 11:54
Hello everyone 🙂
I treat edges and corners with at least the same care as flat surfaces. From my experience, dirt and dust tend to stubbornly settle there, and it’s sometimes not so easy to clean those spots properly without scratching the surface.
For this, I use a soft brush (e.g., synthetic bristle brush) combined with a slightly damp cloth. This allows me to reach the corners and clean gently.
As soon as I feel like I’m rubbing too hard, I prefer to take a break. Gentle cleaning is always better to ensure your shelf lasts a long time 😉
I’d be glad to hear if anyone has other methods!
Paxton38
27 Jan 2024 12:36
Luciandi schrieb:
How do you handle corners or edges that are often more vulnerable than regular surfaces?
That’s a very good question, and it has even become part of certain testing procedures for surface coatings. Edges are indeed subjected to greater mechanical stress and, due to their higher risk of damage, are often more sensitive to moisture.
Therefore, I recommend using a dry, soft cloth when cleaning around edges, and if there is stubborn dirt, carefully clean with a slightly dampened cloth.
It is also important to consider that the laminate layer at the edges may be thinner than on the flat surfaces, which explains the need for extra caution.
Joe52
27 Jan 2024 17:10
tutan schrieb:
I use a soft brush (e.g., synthetic hair brush) combined with a slightly damp cloth.
I really like the trick with the brush and will give it a try.
One more point: Some of you have probably heard of products like furniture wax or polish. Do you think these are suitable for BILLY shelves? Or are they better avoided to prevent altering the surface?
I look forward to your opinions on this – I’m unsure whether it would do more harm than good.
