ᐅ What are the most common assembly issues encountered with the Ikea HEMNES?
Created on: 19 Jan 2021 14:07
pau-tar
pau-tar
19 Jan 2021 14:07
Hello everyone, I am very interested to hear about the specific assembly issues you have most frequently encountered with the Ikea Hemnes furniture. This series is often mentioned in connection with various difficulties, but what exactly about the instructions, parts, or assembly process causes the most challenges for users? Especially when trying to work as accurately and efficiently as possible, it would be helpful to know what to pay special attention to in order to avoid common problems. Perhaps you could also briefly describe how you resolved these issues or if you used any special tools or tricks. Thanks in advance for sharing your experiences!
Dirkmin
19 Jan 2021 14:55
The most common issues when assembling HEMNES furniture can be traced back to a few key points: - Inaccurate drill holes or pre-made holes that do not always fit precisely - Tight-fitting wooden dowels and screws that can often be difficult to insert - Unclear or not always detailed assembly instructions, especially for larger cabinets - Sensitive surfaces that can be easily damaged if handled carelessly In my experience, the most critical aspect is the precise fit of the individual components, as problems can quickly arise if there are slight errors in the sequence or printing mistakes in the instructions. Therefore, I always make sure to check the fit of the parts carefully before assembly and to smooth the screws and dowels slightly or, if necessary, apply a little lubricant to make handling easier.
Lilygla
19 Jan 2021 15:23
I would like to add to Dirkmin’s issues and go into more detail about the most common stumbling blocks I have documented after assembling several HEMNES models.
1. Instructions and parts identification: Although the instructions are generally well-structured, the labeling of individual wooden parts and fittings is often unclear for beginners. This can lead to confusion, especially when similar-looking pieces need to be installed.
2. Screws and connectors: Some of the supplied screws are quite tightly tensioned, making manual insertion difficult. A cordless drill with adjustable torque control is recommended here to avoid damaging the threads.
3. Fit accuracy of the parts: Unfortunately, the pre-drilled holes on some models do not align perfectly. Since the wood is sometimes relatively thin, this can cause damage during adjustments. I recommend test-fitting the fastening points before the final assembly and having a small drill bit or sandpaper ready if needed. Reviewing all fittings before starting assembly is essential for me to avoid mistakes.
4. Weight and stability during assembly: HEMNES cabinets are generally quite heavy, so proper handling and at least two people are required. Uneven loading can loosen the fasteners again.
I would be interested to know: Which exact models are you using? There are sometimes differences depending on size or version.
taudi
19 Jan 2021 16:12
As a supplement and a small tip: If you encounter fitting issues with HEMNES furniture, it is often due to a combination of component tolerances and difficulties with the instructions. My advice is a systematic assembly in three phases: 1. Preparation – sort all parts and check for damage, measure and mark fittings precisely 2. Dry assembly – initially join all parts only temporarily without fully tightening screws, to check the fit 3. Final assembly – once everything fits, insert and tighten all screws and dowels completely. A common and often overlooked mistake (especially with the HEMNES dresser) is confusing the side panels and back panels, which then causes screws not to hold properly. I also recommend always having a rubber mallet ready for installing wooden dowels, as they can easily be damaged otherwise. If possible, use a mounting block (a small piece of wood) to avoid dents and scratches on the visible wood.
pau-tar
19 Jan 2021 17:05
Thanks in advance for the detailed feedback! @Lilygla, I am specifically assembling the three-door HEMNES wardrobe, so the note about hole misalignments could be especially relevant. It’s also good to know that having more people is advisable, as I started alone and quickly realized that the process is hardly manageable solo. @taudi, what exactly do you mean by "confusing the side and back panels"? Are the panels not clearly marked on the outside? Is there a recommended method to prevent this mix-up?
Dirkmin
19 Jan 2021 18:00
taudi schrieb:
A common overlooked mistake (especially with the HEMNES dresser) is mixing up the side and back panels, which then causes the screws not to hold properly.
This is an important point. Additionally, it should be noted that Ikea often uses identical panels in HEMNES models that differ only slightly. As a result, these panels can easily be confused by non-experts without additional markings. My advice: when in doubt, lay the parts out side by side and compare them before final assembly, especially the fastening points and edge profiles. This way, mistakes can be avoided early on.
