ᐅ Which tools are best suited for modifying IKEA HEMNES furniture?
Created on: 22 Mar 2020 08:13
ericra
ericra
22 Mar 2020 08:13
Hello everyone, I am currently planning a renovation of my IKEA Hemnes shelving unit and want to customize it. I am wondering which tools are best suited for remodeling the IKEA Hemnes to achieve precise and clean results without unnecessarily damaging the material. I invite you to share your experiences, especially which tools have proven reliable for different steps (e.g., disassembly, resizing, surface treatment). Thanks for your tips!
draleo
22 Mar 2020 09:47
For the conversion of IKEA HEMNES, I recommend the following tools: - Cordless drill with appropriate bits for disassembling and assembling screws - Jigsaw for modifications to the wooden parts, especially for cutouts - Sandpaper or random orbital sander for surface finishing, to remove wood burrs and smooth the surface - Measuring tape and square for precise measuring and marking - Drill, in case new holes are needed
In my experience, these tools are durable enough and gentle on the materials. It is important to work at low speed to avoid tear-out on the chipboard.
semuneo
22 Mar 2020 10:09
Thank you for your detailed question, ericra! I recently had a similar renovation and can say that I was initially a bit overwhelmed by the tools. What really helped was the advice to test the jigsaw first on a scrap piece to get a feel for the cut – this reduces the fear of ruining the furniture. Also, patience is an important factor. If you want extra security, I would recommend having wood glue and clamps ready in case adjustments don’t fit 100%.
sarlo
22 Mar 2020 11:58
Hello, I’m happy to share my experience for anyone planning to remodel a HEMNES:
1. Cordless screwdriver: Very important for easily removing and replacing screws. Attachments compatible with Torx screws are advantageous, as IKEA mostly uses these.
2. Jigsaw: Perfect for cutting wood panels, but make sure to use a fine-tooth blade to minimize splintering.
3. Wood file or reamers: Useful for smoothing edges after cutting.
4. Sandpaper or sanding sponge: For finishing the surface without damaging the wood grain.
If you’re new to woodworking, I recommend testing the tools in advance—preferably on similar materials not used in the furniture.
Landontau
22 Mar 2020 13:22
Regarding the question "Which tools are suitable for modifying IKEA HEMNES furniture?" I would like to add a brief guide, especially for preparation and execution:
- Preparation: Carefully inspect the construction. The HEMNES furniture is mainly made from solid pine wood, which is relatively soft compared to other wood species, but the finishes are sensitive to the incorrect use of tools.
- Tools in detail:
- Cordless screwdriver with adjustable speed settings, since too high a speed can cause splintering around screw holes.
- For cutting: Jigsaw with a fine blade or alternatively a table saw (if available) for straight cuts.
- Sanding tools: Random orbital sander for larger areas, sanding block with 220 grit for finer work.
- For precise drilling of additional fittings: Drill with wood drill bits of appropriate diameters.
- Common mistakes: Working too quickly when screwing or cutting leads to splintering of the wood. Tip: Always start at a low speed, and score the saw cut beforehand using sandpaper or a utility blade.
I hope this helps!
Israel62
22 Mar 2020 14:11
In short: For remodeling HEMNES, you need a drill driver, a fine jigsaw, and sandpaper. A cordless drill driver with variable speed control is important. That is usually sufficient.
