ᐅ What mistakes should be avoided when assembling IKEA Hemnes furniture?
Created on: 16 Sep 2024 18:27
Noliron
Noliron
16 Sep 2024 18:27
Hello everyone, I am currently planning to use the IKEA Hemnes range for my bedroom furniture and want to make the assembly process as smooth as possible. Since I have read that certain mistakes tend to occur more frequently during the assembly of Hemnes furniture, I would be interested in hearing about your experiences and tips. Specifically: What errors should be absolutely avoided when assembling IKEA Hemnes furniture? This includes mistakes related to the assembly instructions, incorrect handling of screws, or other pitfalls that could complicate the assembly or affect the stability. I look forward to helpful advice, practical tips, and maybe some do’s and don’ts from your own experience. Thank you in advance!
DUVIN
16 Sep 2024 18:45
It is important to first lay out all the parts and check all the screws. Avoid tightening the screws too much before everything is properly aligned. Otherwise, parts may easily become bent.
GiRoyce
16 Sep 2024 19:13
Hello Noliron, your question is very well formulated, I appreciate that! When assembling the Hemnes series, it often happens that the drill holes are confused because some of them look quite similar. My recommendation: double-check every screw and part before you assemble. A common mistake is mixing up the back panel stops – this can cause wobbling later on. Also, take your time when inserting the dowels and use a hammer carefully to avoid damaging the wooden dowels. One last tip from me: it’s best to work with a partner. This makes precise alignment much easier.
Davidleo
16 Sep 2024 19:47
I love Hemnes! And honestly, assembly is really enjoyable once you get the hang of it. What I recommend is never to tighten everything fully right away – first, loosely assemble all parts, then align them, and finally tighten everything. This way, no stress builds up in the wood, and the drawers operate more smoothly. So keep at it, it’s definitely worth it!
Nabla64
16 Sep 2024 20:05
To avoid specific mistakes when assembling the IKEA Hemnes, here is a brief overview based on my personal experience:
- Always work with the instruction manual included in the box, not with copied PDFs, as versions may vary.
- Sort all parts before assembly to quickly find the right ones.
- Pay attention to the correct positioning of the wooden dowels, as incorrect screwing can lead to instability.
- Use a Phillips screwdriver or cordless drill with a torque limiter to avoid over-tightening.
- Take enough time, especially when installing drawer slides, as otherwise the tolerances may not fit.
Conclusion: Patience and careful work make all the difference here.
SETHBLA
16 Sep 2024 20:18
Always make sure not to screw any screws in the wrong way. The Hemnes material is somewhat softer and can be easily damaged. Also, don’t forget to place the slat battens correctly at the back; otherwise, it will be unstable later.
