ᐅ How do I fix loose screws in Ikea Metod cabinets?
Created on: 18 Dec 2023 09:13
NISINAU
NISINAU
18 Dec 2023 09:13
Hello everyone, I have repeatedly encountered the problem with my Ikea Metod cabinets that the screws loosen, especially at the attachment points of the cabinet doors and shelves. I am interested in how you solve this issue in the long term and preferably without having to completely dismantle the cabinets. Is there a proven method to make the screws tight and, above all, load-bearing again? Should the screws be replaced, should special locking agents be used, or should the wood be treated in some way? I look forward to tips and experiences on repairing loose screws in Ikea Metod cabinets.
Franck
18 Dec 2023 09:45
If screws are loose, first check the area for any wood damage. If the wood is intact, simply tighten the screws. Loose drill holes can be filled with wood glue and wood shavings, allowed to dry, and then the screw can be reinserted. Alternatively, use plastic anchors.
U
uslis47
18 Dec 2023 10:07
Hello NISINAU, the issue of loose screws in Ikea Metod cabinets is quite common, especially because the particleboard tends to give way quickly under stress. It is important to identify exactly where the screws are loosening: often, it is at the small connection points that use cylindrical dowels. I recommend carefully removing the screws first. If the holes are already worn out, it helps to fill them with wood glue and small wood pieces or toothpick fragments to give the screw a better grip again. Then let everything dry thoroughly before reattaching the screws. For the cabinet doors, avoid tightening the screws too much, as this can compress the material and worsen the problem. Small plastic anchors (e.g., threaded inserts) can also be useful, but they are not always easy to install. If you have already lost a few screws completely, sometimes using slightly longer screws can help provide better anchoring in the wood.
lajudo
18 Dec 2023 10:55
Simply tightening loose screws again usually only helps temporarily. Apply wood glue and insert toothpicks into the drill holes, let them dry, and then screw the screws back in; this holds much better.
flo-Theres
18 Dec 2023 12:22
A slightly more sustainable tip: If the damage to the particleboard is already significant, you can use so-called Spax wood screws with a slightly larger diameter. The applied tensile force holds better because the screw grips deeper in the wood. Alternatively, a small piece of wooden strip can be glued to the back of the drill holes as reinforcement. This helps distribute the pressure more evenly. It is also important not to use screws with too high a strength rating to avoid over-tightening. As a last resort, thread inserts can be installed in the wood. This is a bit more labor-intensive but provides long-lasting durability.
V
vin_leo
18 Dec 2023 15:03
Franck schrieb:
If screws are loose, first check the area to see if the wood is damaged.
Exactly, and once you understand the root cause, it’s actually quite simple. Are the screws loose? Is the wood soft? Then apply wood glue plus some filler, let it dry, and you’ll have a new, solid hold.
Sometimes it also helps to attach small self-adhesive rubber bumpers to the doors. They reduce the stress on the screw by absorbing some of the pressure. If you move the cabinet frequently, this also helps to reduce wobbling a bit.
