ᐅ Can I combine Malm dressers with other IKEA series?
Created on: 1 Sep 2020 09:17
Toku6
Toku6
1 Sep 2020 09:17
I am currently planning to update my furniture with IKEA pieces and have specifically set my sights on the Malm dressers. My question is: Is it easy to combine Malm dressers with other IKEA series, such as the Kallax shelving unit or the Hemnes line, without significant visual or functional issues? I want to make sure the combination looks harmonious and that any differences in dimensions, colors, or materials don’t cause unexpected problems.
Does anyone have experience with this or can provide more detailed advice on what to watch out for when mixing Malm with other series?
blapau
1 Sep 2020 10:23
Basically, the Malm series is quite versatile due to its simple, modern design. This makes it easier to combine with other series, such as Hemnes, which has a more classic look, or Kallax, which is more functional. In terms of color, there are mainly options like white, white stained, and black-brown, which should be considered when mixing pieces.
Differences in material and surface texture are least noticeable with Malm when choosing, for example, white. Dimensions are a factor since Malm dressers are usually taller than Kallax shelves, but this can be balanced well with appropriate placement or decorations.
My tip: When combining, pay particular attention to the color scheme and proportions, so the furniture does not overpower each other in the room.
Dirkmin
1 Sep 2020 11:04
blapau schrieb:
Differences in material and surface texture are least noticeable with Malm, especially when choosing white, for example.
I agree with that. Additionally, IKEA uses different types of wood for products like Malm and Hemnes, which affects their traditional appearance. The construction of the carcasses also differs technically: the Malm dresser typically has a three-layer particleboard with a laminated surface and less visible edges, while Hemnes is made of solid wood, which influences both the look and the perceived quality.
When combining them, it’s important to be aware that these material differences are visible and should either be deliberately incorporated as a contrast in style or softened by color matching.
TYRELL
1 Sep 2020 12:18
When taking a closer look at the mechanical aspects, there are some technical details to consider when combining Malm dressers with other IKEA series.
First: The back panels and mounting systems differ depending on the series. Malm, for example, often has slimmer back panels and a more rigid corner joint, while Kallax shelves have an open back. When combining these on one wall, alignment issues can arise if you want to connect storage spaces or surface-mounted units.
Second: The height and depth of the furniture vary. Malm dressers are generally taller (around 78 cm (31 inches)) and usually about 48 cm (19 inches) deep, if I am not mistaken, whereas Kallax shelves are deeper (approximately 39 cm (15 inches)). So, if you place a dresser and a shelf directly next to each other, you either have to compromise on the arrangement or add a small platform or base.
Third: The fronts. Malm features smooth fronts, often with integrated grip handles, while other series have knobs or decorative elements. If you want a visually consistent look, this is something to consider carefully.
My advice: From a technical perspective, there are no insurmountable obstacles, but it is worth measuring precisely in advance and aiming for visual harmony.
DULIS
1 Sep 2020 12:47
In short: Yes, you can combine Malm with other series, but pay attention to dimensions and colors. It’s best to measure everything precisely beforehand.
laume
1 Sep 2020 13:30
TYRELL schrieb:
If you want a visually consistent line, you should think carefully about it.
I find this very important because I noticed myself that when combining Malm with Hemnes, the different material appearances immediately stand out. I solved this by using only white dressers and white shelves. This works very well in the room since the color palette remains consistent.
Besides the color, I would also advise you to consider the accessories and handles if you don’t have a handleless option. The handles on Malm are quite minimalist, which doesn’t quite match the Hemnes handles. That’s why I changed the handles on the Hemnes dressers as well to achieve a uniform look.
