Hello everyone, I have a problem with my Ikea Hemnes wardrobe: the fittings squeak with every movement of the doors. I suspect it’s due to the hinges or possibly the sliding mechanisms of the drawers. The squeaking noise occurs mainly when moving the doors slowly, especially when they are only slightly opened. I have already tried tightening the screws, but it didn’t help.
My question to the community is specifically: How can the squeaking in the Ikea Hemnes wardrobe fittings be reliably fixed? What products or methods have proven effective without damaging the material quality or restricting functionality? I would really appreciate detailed tips and experiences, especially with the Hemnes model.
To systematically eliminate the squeaking in the Ikea Hemnes cabinet hardware, I recommend the following procedure:
- Step 1: Remove the hardware for inspection and clean all contact surfaces with isopropanol to remove old lubricants and dirt.
- Step 2: Check all screws for tightness. Loose screws cause friction and noise due to movement.
- Step 3: Lubricate mechanical connections with a non-sticky lubricant, such as Teflon spray or graphite powder. Silicone spray is also suitable, but graphite may perform better where metal contacts metal.
- Step 4: Reinstall the hardware and adjust the door to avoid uneven pressure.
This method has the advantage of addressing the mechanical cause and lubrication separately, providing a long-lasting solution to the squeaking.
PeoDaniel8 Aug 2024 10:03I would like to add: Sometimes the wood itself can squeak slightly when small stresses develop in the frame or joints. This happens especially with higher humidity. In such cases, loosening the cabinet slightly and then tightening it again can help. Occasionally, the drawer slides should also be checked for foreign objects, as these small obstructions can cause and amplify the noise.
If noises persist after cleaning and lubrication, it is worth taking a closer look at the hinges themselves. A common overlooked cause is worn plastic bushings or nylon components within the hinges. In such cases, metal squeaks against the plastic. Replacing these parts or carefully inserting a thin PTFE film can help reduce friction.
GiRoyce schrieb:
Besides cleaning and lubrication, I also recommend checking the door alignment.Good advice, I did notice that the doors are slightly misaligned. I will check and adjust that in the next step.
Kinbu schrieb:
A frequently overlooked cause is worn plastic bushings or nylon parts in the hinges.That sounds plausible to me, especially since the noise has been present for a while. Is there a source where I can get suitable replacement parts for the Hemnes hinges, or are these standard sizes?
Thanks to everyone so far, your answers have been very helpful!
flo-Theres9 Aug 2024 09:12chengi schrieb:
Is there a source where I can get suitable replacement parts for the Hemnes hinges, or are these standard sizes?IKEA itself offers replacement parts for the Hemnes series, although it may take some patience to obtain them. The fittings are usually standard hinges (e.g., 35mm (1.4 inches) cup diameter) that can be found at hardware stores or online as spare parts. However, for exact fit, it is recommended to use the original parts.
Another point: If you are unsure whether the hinge bushes or nylon components are damaged, you can remove the hinges and inspect them visually. Wear is clearly visible through cracks or deformations.
