ᐅ How do Ikea Brimnes hinges work and how do I maintain them?
Created on: 19 Aug 2021 15:07
Etienne44
Etienne44
19 Aug 2021 15:07
Hello everyone, I have a question regarding the Ikea Brimnes furniture series, specifically about the hinges used in these pieces. I am interested in understanding exactly how these hinges work mechanically, to better grasp what happens in case of wear or a defect. Additionally, I would like to know how to properly maintain these hinges to extend their lifespan and possibly prevent squeaking or stiff movements. If anyone has specific tips on how to make opening and closing easier or how to adjust the hinges, I would appreciate a detailed explanation.
LOGEMIN
19 Aug 2021 15:33
Hello Etienne44, your concern is very interesting. The Ikea Brimnes hinges are typically so-called "cup hinges," which are mounted on the inside of the doors. Mechanically, they work through a cylinder recessed into the door (the cup), which clicks into a mounting plate on the cabinet frame. This system allows for both easy installation and removal of the doors.
For maintenance, you should keep the following points in mind:
- Cleaning: Dust and dirt can accumulate, so regularly wipe the hinges with a cloth.
- Lubrication: Use a light machine oil or a special furniture hardware oil. Apply only a small amount, either by spraying or brushing on, to avoid attracting dirt buildup.
- Adjustment: The adjustment screws on the mounting plate allow you to align the door in height, depth, and lateral position, which often helps with stiffness.
A common mistake is using too much lubricant or the wrong greases that become sticky. If something is sticking, readjusting usually helps better than applying force.
Davidleo
19 Aug 2021 15:46
Great question! I’ve had Brimnes cabinets myself, and the hinges are really cleverly designed – they provide smooth and quiet movement. A tip from me: after a few years, the springs might lose some tension. It’s a good idea to occasionally remove the doors and clean and oil the hinges. That will keep them working well for a long time 🙂 Good luck with your maintenance!
Gino38
19 Aug 2021 16:05
For clarification: The function of the Brimnes hinges is based, as LOGEMIN has correctly explained, on an integrated cup hinge with a spring mechanism that supports closing and holds the door in position. When lubricating, avoid using WD-40 or similar products, as they contain solvents that can damage plastics and reduce the effectiveness. Usually, three screws are relevant for adjustment: one for height, one for lateral alignment, and one for the door’s depth. It is advisable to proceed carefully and gradually here.
Daledra
19 Aug 2021 16:41
In short: clean the hinges, lightly oil them, check the screws, and adjust if necessary. This is usually enough to prevent squeaking or catching.
Kinbu
19 Aug 2021 17:12
I would like to add that it is very helpful to be very precise when lubricating, especially if the hinges are located in areas with high humidity. Moisture can affect the mechanics, so in addition to lubrication, occasional checks for rust are also useful. It is also important to remove any excess lubricant with a dry cloth after applying, to prevent dust from sticking, as dirt can accumulate exactly in those spots and impair the function.
