ᐅ How can you fix squeaking in Ikea Hemnes wardrobe fittings?
Created on: 7 Aug 2024 18:27
chengi
chengi
7 Aug 2024 18:27
Hello everyone, I have a problem with my Ikea Hemnes wardrobe: the fittings squeak with every movement of the doors. I suspect it’s due to the hinges or possibly the sliding mechanisms of the drawers. The squeaking noise occurs mainly when moving the doors slowly, especially when they are only slightly opened. I have already tried tightening the screws, but it didn’t help.
My question to the community is specifically: How can the squeaking in the Ikea Hemnes wardrobe fittings be reliably fixed? What products or methods have proven effective without damaging the material quality or restricting functionality? I would really appreciate detailed tips and experiences, especially with the Hemnes model.
SETHBLA
7 Aug 2024 18:39
Hello, it usually helps to treat the hinges and moving parts with a silicone spray or a special furniture oil. It is important not to use regular oil, as it attracts dust. Alternatively, graphite powder can also be used.
neoren
7 Aug 2024 19:05
I would first thoroughly clean all movable fittings. Dirt often accumulates and causes squeaking. Then apply lubricant evenly, for example using a dry lubricant. Liquid oil can attract dirt and make the problem worse.
GiRoyce
7 Aug 2024 20:12
As an additional note: The Hemnes model usually uses simple metal hinges that can start squeaking over time due to friction. Besides cleaning and lubricating, I recommend also checking the alignment of the doors. Incorrect adjustment increases the strain on the hinges. To fix this, slightly loosen the screws, realign the door, and then tighten the screws again.
Additionally, it can sometimes work wonders to lightly coat the hinges with petroleum jelly or graphite. Petroleum jelly provides long-lasting lubrication but can be somewhat sticky, while graphite stays dry and attracts less dust.
dijan
7 Aug 2024 20:53
Hey, while you're working on the screws, also check if the small plastic or rubber parts on the drawer slides are still intact. These can often cause squeaking, and a bit of lubrication or replacement can really help.
And if you want to be on the safe side: silicone spray is your best friend – it doesn’t have a strong odor and remains effective for a long time. Plus, it freshens up the cabinet a bit right away. 😄
SETHBLA
7 Aug 2024 21:22
dijan schrieb:
Silicone spray is your best friend
I completely agree. It is the universal solution for squeaky furniture fittings. Important: Clean the surface beforehand, otherwise it won't work effectively.
