ᐅ Which spare parts are most important for Ikea Hemnes furniture?
Created on: 16 May 2024 09:13
sojan64
Good morning everyone, I have a somewhat more specific question that will likely interest many here who own Ikea furniture: Which spare parts are the most important for the Hemnes series to keep the furniture in good condition for as long as possible? I’m not only referring to obvious parts like handles or screws, but also fittings, runners, or perhaps specific wooden components that are subject to higher wear during typical use. Do any of you have experience with which parts need to be replaced more often or which ones are worth obtaining as spare parts in advance? Thanks for your insights!
koduga schrieb:
I'm also a bit interested in how you handle the replacement if you don't have professional DIY skills – is it easy to do on your own, or better with help?The replacement is quite manageable for non-professionals. Ikea usually provides instructions along with spare parts. A screwdriver is often sufficient. Important: buy original or compatible spare parts to ensure everything fits without issues. For more complex damage (e.g., warped wooden parts), professional help is recommended.
For additional information: Many of the load-bearing parts of Hemnes furniture are made from solid pine wood, which is sturdy but can expand and contract with changes in humidity. This means that screws and dowels may loosen over time. Therefore, I recommend regularly checking the fasteners, such as hinges and drawer slides, as well as the joining elements, and replacing wooden dowels if necessary.
Furthermore, the metal rails of the drawers are quite robust but can bend if the drawer is overloaded. It is important to be cautious and observe weight limits.
To get a clear understanding: How frequently is the furniture used? Is it placed near radiators or in a rather humid room? These factors significantly affect wear and tear.
Surela schrieb:
How frequently is the piece of furniture used? Is it located near any heating units, or is the room relatively humid? These factors significantly affect wear and tear.Thank you for the important follow-up question! I have a Hemnes wardrobe in a bedroom without direct heating and with average humidity levels. The drawers are used daily, and the doors of course as well. So the usage is normal to somewhat heavy, since children also frequently use the furniture. My goal is to have spare parts available to quickly address any initial signs of wear.
In that case, I would especially keep an eye on the drawer slides, the hinges, and the small connecting elements (screws and dowels) for you. Drawer runners can often be replaced quite easily and ensure smooth opening and closing. Hinges are basically the everyday pivots – if they start to wear out, you’ll notice it immediately.
And hey, if you ever tighten the screws, just don't overdo it; that helps keep the wooden parts in good condition for longer. 😉
Finally, a tip for maintenance: When ordering spare parts, it’s worth storing them in a small, labeled box or bag with information about the furniture type and purchase date. This way, you’ll be ready to go when needed.
I also recommend an annual check-up: inspect doors and drawers, tighten screws, and do light care of the wood surfaces. This significantly extends the furniture’s lifespan. With Hemnes, using original Ikea parts means you won’t have compatibility issues, making upkeep straightforward.
I hope this overview helps you and others keep Hemnes furniture functional and looking good for a long time.
