ᐅ Are there any specific tips for using Ikea Hemnes wardrobes?
Created on: 1 Dec 2022 10:13
Maksim58Hello everyone, I’m currently looking into how to make the best use of Ikea Hemnes wardrobes. Are there any specific tips or tricks beyond the usual assembly and standard use? For example, are there particular recommendations for arranging the shelves or adding extra organization components? I’m also interested in how to maintain the stability and durability of these wardrobes, even with frequent use. Maybe someone has experience with practical modifications or useful additions to make their use more efficient? I look forward to detailed tips and advice!
Hello Maksim58, your question is very well formulated, and there are indeed some useful tips for using the Ikea Hemnes wardrobe. First, I would recommend planning the shelves flexibly: don’t use them only for clothes but also for boxes or baskets, so you can store smaller items neatly and keep everything organized. Also, hanging rods installed at different heights help to separate pants, shirts, and long coats in an orderly way.
For stability, it is important to always secure the wardrobes properly to the wall – this significantly improves safety. Another tip is to upgrade with high-quality drawer slides or use metal shelf inserts for greater load capacity.
If you want to know more about the maximum load specifications or discuss specific accessories, feel free to ask.
Deandre schrieb:
Another tip is upgrading to high-quality drawer slides or using so-called metal shelf inserts for increased load capacity.Thanks, Deandre, that sounds interesting. Do you have any specific recommendations on which upgrades work best with the Hemnes? Ikea usually offers mostly basic wooden inserts. Are there any experiences with other manufacturers or universal solutions?
Also, I’m considering whether installing interior lighting is worth it when the wardrobe is packed with items – does anyone have practical experience with this?
The Ikea Hemnes series is based on solid wood construction with relatively sturdy, but not industrial-grade, shelves.
- For increased stability, it is recommended to replace the shelves with metal or thicker particleboard shelves, provided the dimensions match those of the original shelves.
- Ikea drawer slides (e.g., from the Metod range) are compatible but must be measured precisely.
- Third-party interior lighting with LED strips or puck lights works very well and can be retrofitted using simple battery-operated systems without damaging the cabinet.
Important: Pay attention to wall mounting and the maximum load capacity of each shelf (approximately 15 kg (33 pounds) per shelf according to Ikea) to avoid lasting damage.
I also wanted to add something regarding the question about interior lighting, as I implemented this myself. I use battery-powered LED puck lights with motion sensors, which I mounted near the top on the inside. This protects the cabinet since no wiring is required.
Additionally, I recommend arranging the shelves so that frequently used clothes are placed higher up – this saves bending down and improves visibility.
Something else that helped me: simple storage boxes that fit exactly into the shelf compartments to keep things organized.
