ᐅ Are there any known issues with IKEA Hemnes furniture, and how can they be resolved?
Created on: 19 Nov 2022 09:13
sinren
sinren
19 Nov 2022 09:13
Hello everyone, recently I have been looking more closely at the IKEA Hemnes furniture range, especially wardrobes and dressers. I noticed that many users report various issues, such as material quality, stability, or assembly instructions. Therefore, my question is: Are there any known, recurring defects with IKEA Hemnes furniture? And if so, what are the best ways to fix or prevent these problems without having to file a complaint immediately? I am particularly interested in practical tips to improve durability.
plopra
19 Nov 2022 09:35
Yes, Hemnes can sometimes wobble under heavy load. It is important to tighten all screws properly and to retighten any cross connectors. For stability, it often helps to install the back panel very precisely and straight.
kibutar
19 Nov 2022 11:52
I have thoroughly examined the Hemnes bed and dressers. A common weak point is the solid wood used, as well as the particleboard components, which are often prone to chipping at the end edges. Especially with repeated opening of the drawers, fraying can occur after some time. Repair tips for this: - Regularly oil and adjust the drawer slides to prevent jamming - Repair wooden areas with wood filler and sand them down - Reinforce edges with narrow strips if possible
There are also frequent issues with the drilled holes at the wood joints because the fit can vary. I strongly recommend marking all parts before assembly and, if necessary, carefully deburring or adjusting the holes with a drill.
Joe52
19 Nov 2022 13:20
A few months ago, I had a Hemnes dresser that warped after a short time. That was really frustrating, especially because the customer service wasn’t entirely straightforward. But the important thing is to feel that Ikea takes the problems seriously, and often just tightening the screws again or placing a different shelf board in a less stressed position helps. Maybe just ask Ikea customer service for replacement parts. That helped me avoid having to buy everything new right away.
CHENFAR
20 Nov 2022 07:14
In summary, the most common issue with IKEA Hemnes furniture is stability due to imprecise construction of the joints. This problem affects both cabinets and dressers. Rigidity can be significantly improved by readjusting the screw fasteners and reinforcing critical areas, especially the bottom corners and back panels. The use of additional corner brackets from a hardware store has also proven effective. The back panel should be installed precisely without tension to prevent warping.
anfeteo
20 Nov 2022 10:29
Regarding issues with IKEA Hemnes furniture, I would like to provide a brief guide on assembly and troubleshooting:
1. Before assembly: Carefully inspect all parts – tolerances in the drill holes may require some adjustments.
2. Assembly: Do not loosen screws too early, tighten them firmly, and always finish tightening with a screwdriver, not just a cordless drill.
3. Back panels: Check that they fit flush; if not, lightly sand them.
4. Drawers: Regularly lubricate the runners to prevent warping caused by jamming.
5. If there is wobbling: Reinforce with cross braces from a hardware store or install angle brackets.
Summary: The focus is on careful assembly and occasional maintenance to ensure long-term stability.
