ᐅ IKEA Malm Dresser Too Wobbly – How to Reinforce It?
Created on: 29 Jun 2018 08:17
Hiroli
Hiroli
29 Jun 2018 08:17
I own an IKEA Malm chest of drawers and have noticed that it feels quite unstable, especially when pulling out the drawers or when the chest is subjected to slight sideways pressure. This suggests that the construction may lack sufficient stability or that some joints might be loose. My goal is to reinforce the chest in a simple way to make it more stable and secure, without significantly affecting its appearance or requiring too much effort.
Are there any proven methods to effectively stabilize IKEA Malm chests of drawers? I’m particularly interested in solutions that can be implemented using common tools or materials available at hardware stores. Thanks in advance for your advice!
sonpar
29 Jun 2018 08:26
first check that all screws and wall plugs are firmly in place. Then you can screw brackets to the bottom of the back panel to increase stability. An additional board on the back wall also helps.
Laure57
29 Jun 2018 09:02
Hello Hiroli,
your question is well formulated and you have accurately described the issue. The IKEA Malm chest of drawers is often criticized for its low stability because it is mainly made of particleboard and does not use solid reinforcements.
As a first step, I recommend checking all connections again and tightening them if necessary. After that, reinforcing the back panel, for example with an OSB board or plywood panel, can significantly improve stability. You can adjust this so that it is screwed or glued to the back of the chest of drawers.
If you are handy, you can also install small brackets or wooden strips on the inside to further strengthen the corner joints. You should make sure that this does not interfere with the drawers’ function.
I hope this helps! Do you already have specific ideas or certain tools available?
kyledeo
29 Jun 2018 09:15
sonpar schrieb:
Screw the bracket to the back at the bottom
I can confirm that. Also, self-adhesive felt pads under the legs help slightly reduce wobbling if the floor is uneven.
Hiroli
29 Jun 2018 09:41
Laure57 schrieb:
I recommend as a first step to double-check all the connections and tighten them if necessary.
I have partly done that already; all the screws seem to be tight. However, the dresser still wobbles, which probably has to do with the construction itself.
kyledeo schrieb:
I can confirm that. Self-adhesive felt pads under the legs also help a little to reduce wobbling.
It still wobbles on a level laminate floor. Apparently, the connections are somewhat flexible. Reinforcing the back panel sounds interesting. Could you clarify that? How large and thick should the panel be, and how exactly is it attached?
tolokau
29 Jun 2018 10:37
Hello Hiroli,
I can give you a step-by-step guide on how to make the Malm dresser more stable:
1. Check the back panel: Often, the original back panel is just a thin fiberboard, which provides little stability.
2. Replacement back panel: Buy a plywood or OSB board about 6-8 mm (0.24–0.31 inches) thick, cut to fit the back of the dresser.
3. Remove the old back panel or leave it in place if it is not loose.
4. Screw the new back panel from the inside onto the frame of the dresser. Use small, flat screws that secure the panel well to act as a diagonal brace.
5. You can also add corner brackets inside the corners to reinforce the joints between the side and back panels.
6. Important: Remove the drawers beforehand so you can reach the joints easily without damaging anything.
Summary: The new back panel acts like a strong cross brace. This prevents wobbling and significantly increases stability.
If the floor is uneven, you can also install adjustable furniture glides under the feet.
Feel free to ask if you have any questions!
