ᐅ Upgrading Ikea Metod Drawers: Tips and Tricks for Adding Soft-Close Functionality
Created on: 7 Feb 2017 08:12
Kidabau
I have an Ikea Metod kitchen cabinet system with standard drawers that unfortunately do not yet have a soft-close function. I would like to retrofit this soft-close feature to enable quiet and smooth closing of the drawers.
My specific question is: Which mechanical soft-close dampers or systems are compatible with the existing Metod drawers? Are there any important installation tips or tricks I should keep in mind to ensure the damping works optimally while keeping the drawers easy to operate?
I have heard about various retrofit kits but am uncertain about load capacity, material quality, and installation effort. I am also interested in whether upgrading later on is worthwhile or if it is better to buy entirely new drawers with a built-in soft-close mechanism.
I look forward to your experiences and recommendations!
chenlen
7 Feb 2017 13:54
My recommendation: Ikea offers compatible soft-close retrofit kits specifically designed for the Metod system. These are tested for drawer loads of up to 15 kg (33 lbs).
When installing, be sure to pay close attention to the installation depth and ensure parallel alignment.
Retrofit kits are usually worthwhile, both economically and environmentally, compared to purchasing new complete drawer units.
Also important: screws should be tight but must not damage the wood. Pre-drilling is essential if there are no pre-existing holes.
ladali
8 Feb 2017 07:42
According to my research, mechanical retrofit kits with damping modules are ideal for Ikea Metod drawers.
These modules can be attached directly to the drawer side profiles. Installation is done using standardized drill holes that are already present in Metod systems.
After mounting, the damping can be finely adjusted either by screws or by repositioning the damper head.
The dampers not only reduce noise but also minimize material stress and extend the lifespan of the drawer slides.
It is important that the drawers weigh between 3 and 15 kg (6.6 and 33 lbs) for the dampers to function properly.
fojaix
8 Feb 2017 09:17
I installed the Metod Soft-Close adapter, which is screwed into existing side holes.
The installation worked without major issues and significantly improves the lifespan of the drawer slides.
Note that you need to realign the drawer after installation, otherwise it may stick.
Lyndon55
8 Feb 2017 10:05
BASTIANTI schrieb:
Great topic! I love upgrading my Ikea drawers to soft-close because the result is really impressive!
Absolutely!
For retrofitting, I also recommend thoroughly cleaning the drawers before installing the dampers and smoothing out any small irregularities on the runners.
This helps prevent uneven wear on the soft-close mechanism.
Additionally, during the first installation, you should try several closing cycles to find the correct position for the dampers and avoid the drawer jamming.
GLORIA
9 Feb 2017 08:44
Based on my experience, the following points are important for successfully retrofitting the soft-close function on Metod drawers:
- Use original or precisely compatible dampers
- Measure the drill holes carefully
- Perform structured installation with pre-drilling to protect the workpiece
- Adjust the damper force according to the drawer’s weight
Additionally, the drawer must be tested under load after installation, as not all soft-close adapters perform equally well with higher loads.
If you frequently open and close the drawer, investing in higher-quality dampers can be worthwhile, since cheaper models wear out faster.
