ᐅ Glueing fast mount panels!
Created on: 10 Dec 2010 08:19
ikeasteve
ikeasteve
10 Dec 2010 08:19
Hello everyone!
I’m at the stage of my kitchen installation where I plan to attach the wall panels in the next few days.
The base surface will be a smooth hardboard panel.
I also considered using rails, but that will be difficult because the back section is meant to be a passage, which would make sliding the panels in quite complicated. Plus, I couldn’t find suitable rails in four different hardware stores! That’s why I decided to go with adhesive instead.
My kitchen is a single row measuring 2.35 meters (7 feet 9 inches) long, so quite small – and I want to add panels on both the left and right sides, basically forming a U-shape.
Does anyone have experience with gluing wall panels? Mine are satin-finished!
Does it work well? Because the “raw” panels are a bit warped and not 100% flat!
I would really appreciate any tips and experiences!
Best regards, Stefan
schrauberine
15 Dec 2010 07:47
I simply fixed it with a good-quality carpet tape. However, you have to be very careful, as adjustments afterward are difficult.
küchenhexe
30 Dec 2010 19:11
as an experienced IKEA kitchen salesperson, I can tell you that at IKEA we usually advise customers to use either double-sided tape or silicone.
The rails are no longer available, which I personally find unfortunate.
Did you buy the Fastbo for €9.99 (about $11) or the one for €17.99 (about $20)? The €9.99 (about $11) version was discontinued because it was of questionable quality (it warped over time). The €17.99 (about $20) one is the replacement and is more expensive because it is much better.
Hope this helps
küchenhexe
