I recently installed several IKEA Besta drawers in my living room and would like to improve the drawer slides, as I feel they sometimes operate a bit stiffly and do not always close precisely. My question to you is: What options are there to enhance the function and smoothness of the Besta drawer slides without resorting to extensive modifications or expensive replacement parts? I am interested in both simple maintenance measures and technical tips that can be easily carried out by oneself. What experiences have you had with lubricants, drawer runners, or possible modifications that work particularly well with the Besta series?
nesar schrieb:
What options are there to improve the function and smooth operation of the BESTA drawer slides without resorting to extensive modifications or expensive replacement parts?That’s a good starting question. However, it’s important to first clarify what type of slides are installed—whether they are full-extension, partial-extension, or top-mounted rails. Only then can specific recommendations be made. In any case, I find it useful to check the rollers and sliding tracks for dirt and deformation. Often, a thorough cleaning and avoiding cheap lubricants that attract dust can help significantly. What are you currently using to lubricate the tracks?
sifope schrieb:
What are you currently using to lubricate the slides?At the moment, I have not lubricated the drawer slides yet, as I was unsure which lubricant is appropriate. I also read that some oils are not well suited due to dust adhesion. Therefore, I would be interested to know which types of lubricants are recommended for BESTA drawer slides and the best way to apply them.
To improve the drawer slides of the IKEA BESTA series, a multi-step approach is recommended:
- First, completely remove the slides and clean them thoroughly—remove dust, hair, and residues of old lubricants.
- For lubrication, silicone grease or Teflon sprays specifically designed for drawer slides work best. These provide good lubrication while attracting minimal dust.
- Never use thick oil or WD-40, as these attract dust and can interfere with the mechanism.
Additionally, check that all screws and fasteners are properly installed and that the slide rails are not bent in their guides. This can significantly improve smooth operation.
Summary: Cleaning, silicone grease, and proper assembly—this usually works best.
LOJOPAR schrieb:
For lubrication, silicone grease or Teflon sprays specifically designed for drawer slides work best.I can confirm that. It is also important to regularly check the runner rails for small debris or wear marks. IKEA BESTA slides usually use simple ball-bearing systems. The load is not extreme, so clean and proper lubrication is sufficient.
Upgrading to heavy-duty slides can generally be avoided if the existing components are well maintained. If replacement is needed, compatible third-party slides are available, which are usually stronger but also more expensive and complex to install.
