Sektionschef19 Sep 2013 08:02Hello
I want to install a base cabinet in my kitchen rotated so that it’s accessible from the front.
With Faktum, a 60cm (24 inch) base cabinet with a side panel is slightly wider than the depth of a 60cm (24 inch) base cabinet, as shown in the picture.
With Metod, I was surprised to find that the base cabinets are a bit deeper, and at least according to the kitchen planner, the width including the side panel and the depth are the same, see picture.
I assume that if the rotated base cabinet has a door and the hinge is on the side opposite the wall, then I don’t need a filler strip between the wall and the base cabinet, right?
I know we have to wait until Metod is available, but based on the planner at least, I should be able to place a rotated 60cm (24 inch) base cabinet exactly next to another 60cm (24 inch) base cabinet. Does anyone have any other concerns?
Sektionschef
Sektionschef
Z
zetterberg19 Sep 2013 10:32No cabinet dimensions should be the same, see the answer "Faktum countertop with Metod."
Sektionschef19 Sep 2013 11:04No cabinet carcass dimension should be the same, see the answer "Faktum countertop with Metod" Well, if the cabinet carcass dimension is the same but the overall depth of Metod is slightly greater due to the mounting rail compared to Faktum, then the Metod online planner's representation could be correct. I assume it should be possible to screw the rotated US cabinet to the kitchen wall if it has no legs at the back.
Sektionschef
IKEA-Experte19 Sep 2013 14:49Without a jamb, the door will still open, but if it is not hinged towards the wall, it might become annoying if the open door is in the way.
With METOD, you can also install four legs under the cabinet. This is necessary, especially for an island.
Sektionschef19 Sep 2013 15:51Without the stop strip, the door will open, but if it’s not hinged toward the wall, it might be annoying if the open door gets in the way. Thanks for the tip. Could I use these 153Gard hinges for the door so it can open wider?
Sektionschef
IKEA-Experte19 Sep 2013 17:16That is possible. Ultimately, it depends on how the cabinet is used.
