we want to get the Metod kitchen and plan and assemble it ourselves. We will buy everything in two weeks in France.
Now to the specific question: The base cabinets with feet are about 88cm (35 inches) high, but most dishwashers are only 81.5cm (32 inches) tall. Even IKEA France only offers this size. If I buy a dishwasher that is 81.5cm (32 inches) high, that means I would have to attach feet to it, and the front panel would be installed lower than intended.
We want to buy a dishwasher with timerLight technology, which projects the remaining time onto the floor below the dishwasher. This wouldn’t work anymore if the front panel is mounted lower than planned, right?
Am I missing something here?
Regards,
Daniel
Regards,
Daniel
placebo7613 Apr 2014 19:03Why is that actually the case? The 80s front ends 8cm (3 inches) above the floor. It should still open easily even when fixed with external devices, right???
IKEA-Experte13 Apr 2014 20:00I will refer you again to the other post.
placebo7613 Apr 2014 20:36Okay, I understand the issue is not the distance from the floor but the depth towards the base...
Maybe I should just get a standard built-under appliance... Are the integrated ones actually screwed to the neighboring units somehow? Do they stand firmer and have better gap dimensions than the usual slide-in models?
IKEA-Experte13 Apr 2014 21:33It just looks nicer. Metod with a machine without a kitchen front definitely looks a bit makeshift. Get a tall Miele, then you can attach the 80cm (31.5 inches) front to it.
miss-marple14 Apr 2014 15:03Maybe I should just get a standard undercounter appliance... Are built-in ones actually screwed in to the neighboring cabinets? Do they stand more securely and have better gap dimensions than regular slide-under models?Except for free-standing units, which have their own lid on top, you basically can’t just slide a machine in without fixing it. Whether it’s undercounter appliances with a front panel, semi-integrated, or fully integrated dishwashers—all of them need to be screwed in. This can be done either to the adjacent cabinets or to the countertop, provided the countertop is not made of stone, acrylic, etc.
It just looks nicer. METOD with a machine without a kitchen front looks really makeshift. Get a tall Miele, then you can screw the 80cm (31.5 inches) front panel on it.Take a look at Miele’s website for an XXL machine and its installation instructions.
miss-marple14 Apr 2014 17:17Just to follow up,
I recently came across compact dishwashers on the BSH websites (I probably need a new washing machine anyway). The larger model is 60 cm (24 inches) high, about the same height as an oven. They are built-in units with stainless steel front panels. This might be a good alternative to conventional under-counter dishwashers for smaller households. The 60 cm (24 inches) height module should fit quite well into Metod cabinets with their 10 cm (4 inches) and 20 cm (8 inches) height increments, while the smaller dishwashers are 45 cm (18 inches) high, which probably wouldn’t fit as well.
