ᐅ Easily Upgrade and Maintain Ikea Metod Soft-Close Drawer Systems
Created on: 3 Jun 2015 10:07
son_pa
son_pa
3 Jun 2015 10:07
Hello everyone, I am planning to retrofit the soft-close drawer system in my existing Ikea Metod kitchen unit to improve comfort. However, I am wondering what the best approach is to do this without compromising the stability or functionality of the drawers. I am especially interested in which steps are important during the dismantling and installation of the drawer slides and whether there are any special tools or techniques that make the installation easier. It would also be great to learn how to maintain these systems in the long term to keep the soft-close function running smoothly. Does anyone have practical experience or tips that could simplify retrofitting and maintaining the soft-close drawer systems for Ikea Metod?
teo33
3 Jun 2015 10:15
First, completely dismantle the drawer. Unscrew the existing runners and install the soft-close runners in their place. The main tool you will need is a good screwdriver. For maintenance, it is sufficient to keep the runner tracks clean and, if necessary, use some silicone spray.
Josan
3 Jun 2015 10:43
Hello, I can understand your concerns about the installation. With Ikea Metod, it is important to choose the correct soft-close slide for the specific drawer type, as there are models with and without metal runners. It is recommended to carefully remove the drawer, usually by pressing small levers or releasing clips on the sides. Then you can unscrew the old slides. When installing, make sure to align the new soft-close slides precisely so that the mechanism engages properly and the drawer closes smoothly. For maintenance, dust and lint should be regularly removed from the slides, and occasionally a suitable lubricant should be applied – silicone-based lubricants work well and do not negatively affect the closing mechanism.
JONUFA
3 Jun 2015 11:05
Retrofitting soft-close is quick if you use the original fasteners. The guides usually fit directly. Important: Tighten the screws securely and avoid any misalignment. Maintenance is simple: keep clean, do not use oil, but use silicone spray instead.
son_pa
3 Jun 2015 12:22
Thank you for the initial tips! Are there actually any differences in the soft-close systems offered by Ikea depending on whether my drawers are divided or fully extendable? Could something be mounted incorrectly in a mechanical sense? I’m also unclear about whether the soft-close dampers are attached directly to the drawer or to the kitchen front. Is there a clear recommendation or systematic approach for this?
Klakar
3 Jun 2015 12:45
The soft-close dampers are generally installed on the sides of the slides, not on the front. For divided drawers, you can use the same slides, as there are no differences in the mechanism. It is important that the slide is properly adjusted so that the damper effectively slows the movement.
