ᐅ How can I fix squeaking noises in IKEA Metod drawers?
Created on: 16 Dec 2022 08:12
Simona
Simona
16 Dec 2022 08:12
Hello everyone, I have a problem with my IKEA Metod kitchen drawers: they squeak every time they move, whether pulled gently or more firmly. It’s quite annoying, especially because it’s very loud and still persists after several weeks. I suspect it has to do with the sliding rails, but I’m not sure what the best and most permanent solution is. Does anyone know a good method to get rid of these squeaking noises? Should I use lubricants, remove the sliding rails, or are there special products from IKEA or third-party suppliers? I would appreciate any tips, especially if they are long-lasting and easy to apply.
Wesley
16 Dec 2022 08:45
Hey Simona, I know that squeaking all too well – it often happens when the tracks are a bit dry or have small particles stuck inside. A classic solution is to thoroughly clean the sliding tracks and then treat them with a good lubricant. Silicone spray works best because it doesn’t stick and doesn’t attract dirt. It gets tricky if you use “regular” oil or grease since they attract dust and the squeaking comes back quickly. So: clean the tracks, apply silicone spray, and the squeaking will happen less often, guaranteed! 😊
Rhett
16 Dec 2022 09:07
Remove the rails, clean them, apply silicone spray, and reinstall. This is sufficient in most cases.
theo63
16 Dec 2022 09:39
Hmm, I wonder if the material quality of the IKEA Metod rails also plays a role. They are often made from simpler metal or plastic parts that wear out over time and run unevenly. Cleaning and lubricating can help temporarily, but if the track is uneven or components get stuck, the squeaking will persist. Maybe it’s worth checking if there are more durable replacement rails from other manufacturers that run more smoothly in the long term.
islaron
16 Dec 2022 10:12
Cleaning and silicone spray are the quickest solutions. If that doesn’t help, remove the drawers and check if anything is bent or if the roller carriage is faulty. Replacement of the tracks might be necessary.
sinhau
16 Dec 2022 11:03
Hello Simona,
I have a small tutorial for you on how to fix squeaking in IKEA Metod drawers:
1. First, pull the drawer out completely and carefully inspect the sliding mechanism.
2. Use a damp cloth or a brush to remove dirt and dust. Pay special attention to moving parts.
3. Check if the runners are bent or damaged – if so, replace them.
4. Then, apply a thin layer of silicone spray to the runners. Avoid using oil on plastic parts.
5. Slowly slide the drawer back in and move it several times to distribute the lubricant.
Common mistakes are applying too much lubricant or using oil-based products that attract dust. If you want, do this about once a year to keep them quiet.
Hope this helps!
