ᐅ How can the Ikea BRIMNES be disassembled without damage?
Created on: 17 Jan 2022 08:14
heinolis32
Hello everyone, I’m planning to disassemble and rearrange my Ikea Brimnes wardrobe, but I want to make sure that none of the parts get damaged or warped during the process. My question for the experienced users: How can you disassemble the Ikea BRIMNES without causing any damage? Are there any special tools or techniques I should be aware of? I’m especially interested in the best way to remove the back panel, hinges, and the connecting fittings to keep the structure intact. Any tips are much appreciated!
heinolis32
17 Jan 2022 10:27
Thanks for the tips so far. I’m wondering: Is there anything special to consider when it comes to the hinges? Removing them seems particularly tricky since they hold the door securely. Is there a specific order I should follow? Also, what’s the best way to gently separate the boards without damaging the corners?
FRANCISCOP
17 Jan 2022 11:05
The hinges of the Brimnes are usually mounted on a clip system, which means you need to unlock them first before unscrewing. Always use a suitable screwdriver (Philips or Pozidriv, depending on the screw), as slipping tools can cause surface damage. When separating the boards, first loosen the connecting fittings, then carefully pull them apart—make sure to pull straight at the edges, avoiding prying.
TELAHAU
17 Jan 2022 11:38
Unlock the hinges, loosen the screws, carefully pull the boards together. Do not pry.
BEMAU
17 Jan 2022 13:17
heinolis32 schrieb:
Do you need to pay special attention to the hinges? Their removal seems particularly tricky since they hold the door securely. Is there a specific order I should follow? Also, how can the boards be separated gently without damaging the corners?
For removing the hinges: first, take the door off by carefully pressing the retaining clips on the hinge or gently prying them off with a small screwdriver. Then, unscrew the hinges themselves using the appropriate screwdriver. Avoid twisting or levering during this process. Once all connectors are removed, separate the boards by pulling them slowly and straight apart. To prevent damage to the edges, it is recommended to place cardboard strips or soft padding under the furniture to avoid pressure marks.
reni45
17 Jan 2022 14:04
Remove the door, unscrew the hinge, carefully take off the back panel, loosen the connecting fittings, then slowly separate the boards. This helps prevent damage.
V
vin_leo
17 Jan 2022 15:21
rekijan schrieb:
If you put the screws in small bags and label them, you keep track and avoid stress later.😉
I completely agree! Never have to hunt for screws again – I even mark the boards and rooms briefly to prevent mistakes later. A little organization makes things much easier.
