ᐅ Replacing BILLY Shelf Hinges: What Are the Alternatives?
Created on: 27 Apr 2023 08:23
Stella32
Stella32
27 Apr 2023 08:23
Hello everyone, I noticed that the original hinges on two of the five doors of my Ikea Billy bookshelf have worn out quite a bit. The doors no longer close properly and hang slightly crooked. Now I’m considering replacing the hinges entirely. My question to you: What alternatives to the original BILLY hinges are available that are at least equal in quality or better? It would be great if you could share tips on durable, easy-to-install replacement hinges and maybe also some advice on compatibility with the BILLY shelf. Thanks in advance!
lubla
27 Apr 2023 08:45
I recommend Blum hinges; they often fit without any issues. They are high quality and very durable.
Espen
27 Apr 2023 08:46
Hettich hinges are a good alternative and generally fairly priced. They are easy to install.
Stella32
27 Apr 2023 09:12
Thanks, that’s already helpful. Do you know if new drill holes are needed for Blum hinges, or do they fit exactly into the existing holes of the Billy shelf? This is important for me because otherwise the wood can get damaged quickly.
daalessio
27 Apr 2023 10:03
Blum hinges are known for using standard drilling dimensions. Usually, the original positions can be reused, but there are differences in drilling depth and door thickness. If no new holes are desired, it is important to pay close attention to the model designation. It is best to test them at the hardware store or check the technical datasheets.
BOLUKEO
27 Apr 2023 10:27
If the drill holes do not align, I recommend using furniture hinges with adjustable mounting plates. This allows you to compensate for minor deviations without having to drill new holes.
