Hello everyone, I’m planning to disassemble and rearrange my Ikea Brimnes wardrobe, but I want to make sure that none of the parts get damaged or warped during the process. My question for the experienced users: How can you disassemble the Ikea BRIMNES without causing any damage? Are there any special tools or techniques I should be aware of? I’m especially interested in the best way to remove the back panel, hinges, and the connecting fittings to keep the structure intact. Any tips are much appreciated!
heinolis3218 Jan 2022 08:47Additionally, I have a question about the back panels: Are they nailed or stapled? Is it worth using a special tool to remove them, or is a small screwdriver sufficient? I want to avoid the back panel breaking or splintering in case I want to reuse it.
heinolis32 schrieb:
Are they nailed or stapled? Is it worth using a special tool to remove them, or is a small screwdriver enough?Brimnes back panels are usually attached with fine staples or small nails. A flat, sturdy screwdriver or a small pry bar is sufficient. It is important to work carefully and step by step. A special tool is not strictly necessary, but a thin lever tool with a wide contact surface reduces the risk of cracks and dents.
heinolis3218 Jan 2022 12:47Great, thanks for the tips on the tools and handling the back panel. I will use small lever tools and carefully release the clips one by one instead of prying. If I have any more questions, I’ll get in touch again!
