ᐅ How can I assemble Billy shelves without using any tools?
Created on: 13 Sep 2021 18:02
Azizulla42
Hello everyone, I have a question regarding the assembly of the Billy shelves from IKEA. Is there a way to assemble these shelves completely without any tools? I want to avoid using screwdrivers or drills because I either do not have tools available or want to keep the assembly as simple and flexible as possible. Does anyone have experience or tips on how to securely and stably set up the Billy shelf without using conventional tools? I look forward to your suggestions and ideas!
Daledra
13 Sep 2021 20:29
Billy is not really designed to be assembled without tools. If you don’t have a screwdriver, a coin or a sturdy plastic spoon can also work as a temporary tool for the Phillips-head screws.
Azizulla42
14 Sep 2021 07:45
Daledra schrieb:
If you don’t have a screwdriver, a coin or a sturdy plastic spoon can also work as a temporary tool for Phillips screws.
Thanks for the tip, that sounds very helpful! I’m wondering if this method will be sturdy enough without using the proper tools. Has anyone had experience with how well improvised tools hold up, especially when the shelf is loaded later on?
koneo
14 Sep 2021 08:30
Using improvised tools like a coin or spoon is possible, yes. It will make the assembly easier if no screwdriver is available. However, the stability depends more on the correct positioning of the anchors and screws than on the type of tool used. If the screw is properly fixed, the shelf will hold well even with these tools. A cordless drill is still the best solution for maximum stability.
Karsten45
14 Sep 2021 10:02
Stability and tool-free assembly are unfortunately rarely best friends 😅 But everything is worth trying! If you want to use the shelf for a short time with light loads, clamping strips or edge protectors that can be attached without screws might also help. Not exactly IKEA standard, but quite handy for a quick team setup.
Azizulla42
14 Sep 2021 12:18
I would like to add that I plan to place the shelf in an area where no heavy loads will be stored. Mainly a small number of books. Therefore, a provisional, minimalist installation without major tools would be ideal. Also, is there any special accessory for Billy that works without screws, or are such alternatives more likely to be found from third-party suppliers?
Marlenepa
14 Sep 2021 13:10
Hello Azizulla42, regarding your question: IKEA does not offer a special tool-free assembly system for the Billy bookshelf. The design relies on screws and wall plugs. However, there are brackets and clips available on the accessories market that work without tools. These, however, are not officially compatible and can sometimes cause instability. For light loads, though, this can work quite well. Your idea to store books relatively lightly is sensible in this context. I would recommend a combination with minimal tools—such as using a belt as a lever for screws or a small hand drill—to ensure safety.
