I am planning to assemble an Ikea Kallax shelving unit and want to use the appropriate screwdriver for it. My specific question is: which screwdriver is best suited for assembling the Kallax unit, especially considering the included screws and the connecting hardware?
So far, I have often used Phillips screwdrivers, but I wonder if a common Phillips screwdriver is sufficient or if it is better to use a precisely matching Pozidriv or Torx screwdriver.
Has anyone had experience with assembling the Kallax and can offer recommendations that also focus on durability and preventing screw damage?
Thanks in advance for your tips!
juzar49 schrieb:
Which screwdriver is best suited for assembling the Kallax shelving unit?Interesting question! In my opinion, the whole discussion about "the perfect screwdriver" is often exaggerated. Of course, using the right Phillips head is convenient, but Kallax is designed with built-in Ikea tolerances anyway. Any standard Phillips screwdriver is sufficient for a shelving system intended mainly for home use.
Believe me, an expensive Torx screwdriver is rather unnecessary in this case, since the screws are not professional construction screws but simple furniture connectors.
As an additional note: Ikea Kallax typically uses screws with a Phillips (PH) head.
A Phillips PH2 screwdriver is ideal because it matches the standardized shape of the screw heads, preventing slipping.
Pozidriv or Torx drivers are not necessary and can even damage the screw head if used incorrectly.
Therefore, I specifically recommend a good PH2 screwdriver with an ergonomic handle for better grip during longer assembly tasks.
To explain the topic in more detail:
1. Tool: For assembling Kallax, a Phillips screwdriver size PH2 is suitable, as Ikea typically uses standard screws with Phillips heads.
2. Why PH2? It fits precisely into the screw recess and prevents slipping or cam-out, which can damage the screw head.
3. Common mistakes: Some use smaller or larger bits – these can cause cross-threading or rounded screw heads.
4. Tip: When using cordless drills, keep the torque control activated and work at a low speed.
5. Conclusion: There is no need to buy expensive specialty bits; a solid Phillips PH2 screwdriver, preferably with a non-slip handle, is sufficient.
Lamar schrieb:
the whole discussion about "the perfect screwdriver" is often exaggeratedAlthough that is true, I believe precision in tools is essential. Kallax screws are simple, but when working with cam connectors, it’s important to use a precise PH2 screwdriver without a damaged tip.
This helps avoid problems with stripped screw heads and ensures a secure fit.
