ᐅ Why are the Malm hinges sometimes loose?
Created on: 14 Oct 2020 08:17
nuli63
I have been experiencing an issue with the hinges on my IKEA Malm furniture for some time now, where some of them have become quite loose. My question is: why do the Malm hinges become loose over time? Specifically, the doors no longer fit tightly and feel somewhat wobbly. Are there known design weaknesses, material fatigue, or is this simply normal for this model? I would appreciate a detailed explanation of the possible reasons and any sustainable solutions to address this.
laureo
14 Oct 2020 11:05
It is true that furniture like the Malm series from IKEA is not designed for maximum long-term durability on an industrial scale due to its construction and choice of materials.
The thin particleboard is more susceptible to screw pull-out compared to solid wood. While the hinges are sturdy, their hold in particleboard weakens more quickly.
A sustainable solution, when simply tightening the screws no longer works, is to insert wooden dowels or use special screws designed to repair stripped holes. In some cases, users also replace the hinges with stronger models to achieve better stability.
A warranty claim with IKEA is unlikely in this case, as this is considered normal wear and tear.
nuli63
15 Oct 2020 07:48
laureo schrieb:
Thin particleboard is more prone to screw pull-out than solid wood.
Thanks, you're probably right. I tried a few times to fix the screws on a hinge with wood glue. In the end, it holds for a while, but the door then feels rather stiff.
refinar schrieb:
Completely loosen the screws, clean the wood threads, and if necessary reinforce with wood glue or small wooden dowels.
Maybe I’ll actually try wooden dowels for the particularly loose hinges. Does anyone have tips on how to properly install wooden dowels without misaligning the door?
refinar
15 Oct 2020 08:22
Here is a brief instruction:
1. Loosen the screws on the hinge and remove the hinge.
2. Apply a small amount of wood glue into the drill hole.
3. Lightly coat a suitable wooden dowel (matching diameter and length) with wood glue and insert it into the drill hole.
4. Let it dry – at least a few hours, preferably overnight.
5. After drying, carefully saw the dowel flush, and if necessary, lightly sand it.
6. Reattach the hinge and carefully tighten the screws.
Important: Only fully tighten the screws once the glue is dry. Make sure you can still properly adjust the hinge on the door before final tightening so the door sits flush and does not stick.
If done correctly, this method holds much better than screwing directly into loose wood.
Tause
15 Oct 2020 09:01
nuli63 schrieb:
Could it be that this is a typical weak point in the Malm series, perhaps a design decision by IKEA related to the thin wood and cost-effective construction?
Interesting point! It is also worth critically examining whether IKEA uses the cheapest materials for the hinges to keep the series price low.
Furthermore, it is rarely checked whether the assembly by customers is done correctly. Even small installation errors can contribute to the loosening of the hinges.
Is there any information on how IKEA addresses this issue in product development? Or are customers left to rely on their own repair methods?
Pome60
16 Oct 2020 11:37
So guys, I just wanted to say: I simply ordered stronger hinges and replaced the old ones! Now everything is super stable with no more wobbling 🙂
So, if tightening screws and wooden dowels don’t help – definitely try better hinges. It’s a total upgrade!!!
refinar
16 Oct 2020 12:10
Pome60 schrieb:
I simply ordered stronger hinges and replaced them! Now it’s super stable with no more wobbling 🙂
That’s a good, practical solution! For those considering replacing and adjusting, I also recommend checking the door’s alignment in the same step to evenly distribute all stresses.
With more affordable furniture, repair is often the most sustainable option as long as all parts fit. Thanks for sharing your experience!
