ᐅ How can I securely fix IKEA Platsa units to tiled floors?
Created on: 9 Aug 2022 18:07
faustinofl
faustinofl
9 Aug 2022 18:07
I am planning to place an IKEA Platsa furniture set on my tiled floor. Since the Platsa units are mainly designed for flat surfaces, I am concerned about stability, especially because tiles can be somewhat slippery and the furniture might slide more easily. My question is: How can I securely and stably fix IKEA Platsa on a tiled floor without damaging the floor or affecting its appearance? Are there any special tips to prevent slipping or wobbling, or perhaps proven methods you would recommend in such cases?
I want to avoid any risk since the furniture will become quite heavy when fully loaded. I would greatly appreciate any professional advice or practical experience.
Espen
9 Aug 2022 19:41
faustinofl schrieb:
How can I securely and stably fix IKEA Platsa to a tiled floor without damaging the floor or affecting the appearance?
The easiest way is to place self-adhesive anti-slip pads under the furniture feet. Alternatively, you can use furniture anchors attached to the wall to prevent tipping.
kulau
10 Aug 2022 08:22
faustinofl schrieb:
How can I securely and stably fix IKEA Platsa to a tiled floor without damaging the floor or affecting its appearance?
The challenge with tiled floors is their smooth surface combined with possible unevenness in the grout lines. IKEA Platsa is modular and typically does not include floor fastenings, as the system is usually anchored to the wall. To safely support the load and prevent slipping, I recommend the following approach:
- First, place soft, rubberized anti-slip pads under the legs. These increase friction and protect the tiles.
- Additionally, secure wall mounting using the brackets provided by IKEA is very important to prevent tipping.
- If the grout lines are noticeably uneven, thin foam rubber or foam pads can be placed under the legs to level the floor.
- Drilling screws or anchors into tiled floors is only advisable if you have experience with tile drills, as cracking can easily occur otherwise.
- As an alternative, a stable base board (for example, a thin plywood panel) can be placed under the furniture and made slip-resistant. This distributes the weight better and can be combined with anti-slip pads.
In conclusion: The combination of wall mounting and appropriate anti-slip solutions beneath the legs is crucial for a secure installation without damaging the floor.
Charles
11 Aug 2022 11:13
kulau schrieb:
The combination of wall mounting and suitable anti-slip solutions under the feet is crucial for a secure installation without damaging the floor.
I fully agree with this. Additionally, I would recommend thoroughly cleaning and degreasing the subfloor before installation to ensure the anti-slip pads adhere optimally.
For the wall mounting, it is important to use appropriate anchors that can support the weight of the fully loaded modules. In some cases, using construction adhesive on the feet can help if wall mounting is not possible – however, I would only suggest this as a last resort, as it may leave marks.
If you also want to avoid damaging tiles, protective felt pads under the feet are an alternative. They provide some cushioning and prevent scratches but do not restore the slip resistance, which is why wall mounting remains advisable.
