ᐅ How do I fix Ikea PLATSA screws that have come loose?
Created on: 22 Nov 2021 08:12
tale51
tale51
22 Nov 2021 08:12
Hello everyone, I recently assembled an Ikea Platsa shelving unit, but I noticed that some of the screws loosen again after a short period of time. This especially concerns the connections secured with the included screws, which are often used as connector fittings. My question is: How can I effectively fix or rework these Ikea PLATSA screws to prevent them from loosening repeatedly? Are there proven methods to secure the screw connections without damaging the material or complicating the assembly? I look forward to your tips and experiences.
boelnu
22 Nov 2021 08:34
tale51 schrieb:
How can I effectively repair or rework these Ikea PLATSA screws so they don’t keep loosening?
I know exactly how frustrating it is when you put time and effort into assembling something, and the screws still become loose. One method that helped me is carefully applying wood glue or a special wood screw adhesive to strengthen the screw hold. Make sure to use only a small amount so the screw can still be driven in without damaging the fitting. It may feel a bit uncertain to use glue, but it helped me prevent the screws from loosening again.
Kurtis5
22 Nov 2021 09:05
Loosen the screws slightly, apply wood glue to the screw holes, then tighten the screws firmly again. This stabilizes the connection. As an alternative to filling with wood glue, small wooden wedges can also be used for loose holes.
FEKAU
22 Nov 2021 09:45
For the long-term securing of loosened screws in Ikea PLATSA furniture, I recommend a targeted approach:
- First, carefully unscrew the loose screws to avoid further damage to the material.
- Then, insert small wooden or plastic wedges into the already enlarged drill holes to narrow the opening.
- This ensures a firmer grip when re-inserting the screws.
- In cases where the wood is too damaged, consider filling the area with wood filler and re-drilling after it has dried.
These steps generally provide stable connections without the need for additional products such as adhesives.
boelnu
22 Nov 2021 10:17
FEKAU schrieb:
As an alternative to wood glue filler, there are also small wooden wedges for loose holes.
I haven’t tried the wedges often enough yet, but they are definitely worth considering, especially for thinner panels where the screw holes tend to enlarge quickly. You just have to make sure the wedges fit tightly and don’t slip out of the hole as you drive in the screw.
FRANCISCOP
22 Nov 2021 11:08
A technically sound method is to not only narrow the screw holes using wedges but also to use self-locking washers or thread-locking compounds. This is especially worthwhile for furniture subjected to frequent stress to ensure long-lasting stability.
Furthermore, a good repair includes checking and retightening the screws after a few weeks – fittings often loosen after the initial load. Important: Tighten the screws only by hand to avoid stripping the wood material.
