ᐅ Are there installation alternatives for IKEA PLATSA that do not require drilling?
Created on: 15 Mar 2024 08:17
file64Hello everyone,
I am planning to get an IKEA Platsa wardrobe system, but I have the problem that I am not allowed to drill in my rental apartment. Therefore, my question is: Are there any installation alternatives for IKEA PLATSA without drilling that are still sufficiently stable and secure?
Since the system is modular and usually mounted on the wall, I am wondering how else such furniture could be fixed. Maybe someone knows creative solutions or special products that allow for good fastening.
I look forward to tips and experiences!
Assembly without drilling is generally difficult with IKEA PLATSA, as the system is primarily designed for wall mounting using screws to reduce the risk of tipping.
Alternatives without drilling include:
- Using heavy, non-slip floor seals or rubber pads to prevent sliding
- Clamp or tension systems secured between floor and ceiling (though currently not widely standardized for PLATSA)
- Using special adhesive tapes or mounting adhesives suitable for furniture (usually not suitable for heavier loads)
It is important to check stability and safety, as a tipping piece of furniture can pose a hazard, especially to children or pets.
I can help here in a more structured way and explain different options that could work without drilling.
1. Tension rods between floor and ceiling:
- These can be adjusted and often apply enough pressure to hold lightweight shelves.
- For PLATSA, some modifications might be necessary, as the modules are not specifically designed for such systems.
2. Self-adhesive furniture brackets:
- They only partially replace wall mounting since the adhesive strength and load capacity are usually limited.
3. Anti-slip mats under the modules:
- Prevent sliding on smooth floors.
4. Anchoring to adjacent furniture:
- An unconventional solution, involving a fixed connection to other stable furniture.
It is important to note that all these alternatives usually cannot fully replace the safety intended by the manufacturer.
KAULIS schrieb:
Alternatives without drilling could be:
- Use of heavy, non-slip floor pads or rubber mats to prevent slipping
- Clamping or tension systems that lock between floor and ceiling (though currently not widely standardized for PLATSA)
- Use of special adhesive tapes or mounting adhesives suitable for furniture (usually not suitable for heavier loads)I would like to add some technical details here, as safety during the assembly of PLATSA should never be taken lightly.
If you are considering a clamping or tension system: the ceiling height, the nature of the floor, and the exact dimensions of your PLATSA cabinet are crucial. Such systems only work effectively if they can be secured with sufficient pressure that is statically relevant.
Additionally, mounting adhesives or double-sided tapes on wooden surfaces often pose a greater risk. They can lose adhesion due to temperature fluctuations or moisture, which is why I would recommend them only for very light modules.
The ideal solution would be a combination: heavy floor gliders (anti-slip), additional connections between the panels, and possibly an adapted tension rod system to stabilize the side panels.
Have you already checked the dimensions of the available space and any potential restrictions regarding ceiling height?
bapar schrieb:
Have you already checked the dimensions of the possible installation area and any restrictions regarding ceiling height?Yes, the ceiling height is 2.45 meters (8 feet), and the installation area is about 2 meters (6.5 feet) wide with a standard depth. The PLATSA units are mainly intended for storing clothes and a few books. I would prefer a solution without any holes in the wall, as the landlord is very strict and I want to avoid any disputes.
The idea of a tension system sounds interesting, but how could it be implemented in practice? Are there any examples or user experiences regarding how stable such a system can really be?
file64 schrieb:
The idea of a tension system sounds interesting, but how could this be implemented in practice? Are there any real-world examples or experience reports on how stable such a system can actually be?Tension systems installed between floor and ceiling achieve their stability through friction and the mechanical pressure they generate. They usually consist of metal or wooden rods with adjustable end fittings.
In practice, these systems are more commonly used for room dividers or shelving units that cannot be fixed to walls (for example, in rental apartments). For PLATSA, however, the following should be considered:
- The tension rods must be precisely adjusted to prevent tipping.
- An additional connection between the PLATSA units and the tension rods should be created to minimize lateral movement.
- Because pressure distribution can cause damage to floors or ceilings, protective pads are advisable.
Stability can be quite good if the components are properly dimensioned, but for tall cabinets like PLATSA, wall mounting is still the more secure option.
