ᐅ Are there installation alternatives for IKEA PLATSA that do not require drilling?
Created on: 15 Mar 2024 08:17
file64
I am planning to get an IKEA Platsa wardrobe system, but I have the problem that I am not allowed to drill in my rental apartment. Therefore, my question is: Are there any installation alternatives for IKEA PLATSA without drilling that are still sufficiently stable and secure?
Since the system is modular and usually mounted on the wall, I am wondering how else such furniture could be fixed. Maybe someone knows creative solutions or special products that allow for good fastening.
I look forward to tips and experiences!
farGlen
16 Mar 2024 07:55
I set up similar furniture without drilling: I placed non-slip mats underneath and used heavy books as weights at the bottom. This keeps the furniture relatively stable without the need for drilling.
KAULIS
16 Mar 2024 09:14
farGlen schrieb:
I have installed similar furniture without drilling: I placed anti-slip mats underneath and used heavy books as weights at the bottom.
This is a practical solution, but it is only suitable for low to moderate tipping risk and should never be used in homes with children or pets that could easily knock over the furniture.
A surprisingly simple alternative could be furniture corner brackets fixed with high-performance adhesive, on non-porous floors (such as tiles). However, there is no general recommendation from IKEA for this.
mauka
16 Mar 2024 11:27
Mounting large furniture without drilling always sounds tricky. But maybe a bit of creativity can help!
- Tension rods could actually work well (even if they are not officially designed for Platsa)
- Non-slip mats are great, plus a few heavy boxes at the bottom to prevent wobbling
Perhaps there’s also some clever DIY mounting system out there – the main thing is that the furniture is stable and the landlord stays happy!
Davidleo
16 Mar 2024 14:48
I would say: Don’t be afraid to try some solutions without drilling! 😀 Especially with tension rods or non-slip pads, you can often achieve more stability than you might expect.
Of course, fixing things to the wall provides the most security, but in rental apartments, you can’t always have everything.
If you give it a try, please share how stable it turned out to be! These kinds of alternatives are really interesting and could help many people here in the forum!
SUBEN60
17 Mar 2024 08:05
Summary and my recommendation:
- The IKEA PLATSA system is designed for wall mounting, and all alternatives involve compromises.
- Tension rods between floor and ceiling are the most effective alternative when drilling is not possible; make sure to adjust them correctly and consider padding if necessary.
- Non-slip materials under the furniture and even weight distribution toward the floor increase safety but do not replace wall anchoring.
- Adhesive solutions are generally not reliable for long-term load and should be used with caution.
In conclusion: Always check the stability before use, especially if children or pets are present. Safety must come first.
