ᐅ Are there IKEA PLATSA furniture units with integrated handle strips?
Created on: 29 Jul 2017 08:47
DarraghHello everyone, I recently looked into the IKEA PLATSA series and I’m wondering if it’s possible to equip these furniture units with integrated handle strips? I noticed that many IKEA kitchen and furniture series offer handle strips as a practical and stylish solution, but the PLATSA models didn’t seem very clear in this regard. I would like to know if there are official PLATSA units with built-in handle strips or at least a compatible option from IKEA to retrofit them. If not, it would also be interesting to hear if other users here have experience with alternative solutions. Thanks for your detailed answers!
Basically, IKEA does not offer special fronts with integrated handle strips for the PLATSA series. The system is designed to be very flexible, which means you can choose fronts without handles and then come up with your own solutions. Many people order separate handle strips or profiles and install them themselves. Technically, attaching handle strips to PLATSA fronts is quite straightforward since the fronts have standardized mounting points. However, you should pay attention to the material of the fronts, as they are usually made of thin particleboard, which is not very durable when drilling. I recommend doing a small test drill before installation to avoid splintering. If you decide to use handle strips from third-party manufacturers, be sure to check the dimensions carefully, as PLATSA fronts can vary in width and height. By the way, what type of handle strips do you have in mind? Aluminum, plastic, or wood? Each option has different advantages regarding durability, appearance, and installation effort.
I am a bit skeptical when it is simply assumed that a series like PLATSA must automatically be compatible with handle rails. IKEA markets PLATSA specifically as a customizable system with great options for fronts and panels, but the handle rail as a design element is not part of the standard offering. Therefore: Are there any concrete indications from IKEA suggesting an official handle rail for PLATSA? I found none.
I agree with that.
And to me, that is the logical conclusion: If you want handle rails, you need to choose other series, such as BESTÅ or METOD.
Anyone claiming otherwise should please provide verifiable sources.
Roberta schrieb:
The PLATSA series basically does not have furniture with integrated handle rails from IKEA.
I agree with that.
In summary: IKEA does not offer prefabricated furniture with handle profiles for PLATSA, but its modular design allows for custom solutions. Here is a brief overview of common handle profile options and installation tips for PLATSA:
- Handleless fronts: have no visible handles or profiles, usually operated with push-to-open or pull mechanisms.
- Mounting handle profiles as separate components: typically on fronts that can be easily drilled.
- Handle profiles like those offered for METOD or BESTÅ often do not fit without modifications due to different front materials and edge dimensions.
Installation tips:
1. Check the edge corners before drilling the fronts.
2. Use thin drill bits for pilot holes.
3. Make sure the profiles are aligned properly so they sit straight.
In the end, it’s a matter of personal skill and planning.
In short: Officially no, but DIY is possible.
If desired, I can gladly prepare a step-by-step guide for attaching a handle profile to PLATSA.
Installation tips:
edisondan29 Jul 2017 13:17In fact, IKEA does not list any PLATSA fronts or furniture with integrated handle rails in its official product details. The PLATSA series features a simple, mostly handle-free design or fronts with traditional handles that are mounted separately.
From a technical perspective, the fronts are not ideal for elaborate handle rail profiles due to their material thickness and edge processing, unlike kitchen systems such as METOD. For users who still want a handle rail-like solution, the following options are available:
- Clamp rails attached with double-sided tape or screws
- Custom modifications by a carpenter or skilled DIY users
I recommend carefully reviewing technical drawings or measurements before installation. IKEA does not offer such a solution for PLATSA as standard.
