ᐅ How can I assemble IKEA Metod tall cabinets easily and safely?
Created on: 9 Aug 2023 10:17
Joachimfi
Joachimfi
9 Aug 2023 10:17
Hello everyone, I am planning to equip my new kitchen soon with IKEA Metod tall cabinets. Since I have relatively little experience assembling large furniture, I would like to know: How can I assemble IKEA Metod tall cabinets easily and securely to ensure nothing goes wrong and all cabinets end up standing stable? Are there any special tips for installation that I should definitely pay attention to, especially regarding wall mounting and assembling the modules? I look forward to your tips and experiences!
Ethan
9 Aug 2023 10:45
Hello Joachimfi, a very good topic! Assembling Metod tall cabinets can indeed be tricky if you don’t know the right steps. It’s important to always follow the assembly instructions step by step and not rush. A few basic rules: - Allow enough space for assembly and sort all parts according to the instructions beforehand. - Use the included tools or appropriate screwdrivers to avoid damaging the screws. - Most tall cabinets consist of several modules that should first be assembled separately and then connected. A stable assembly mainly results from accurately aligning the side panels and firmly securing all connection points with screws. - Wall mounting is especially important for safety and prevents tipping. Be sure to use suitable wall plugs for the type of wall (e.g., concrete, drywall) and tighten the screws firmly. This is the most crucial safety point, especially if you plan to equip the cabinet with heavy appliances later. If you no longer have the instructions, feel free to ask – I can provide a detailed summary again. In general, work calmly and systematically; that is the key. Good luck!
nedagla
9 Aug 2023 11:22
Hey Joachimfi, you’ve got this! Modular wall units are really practical, and the assembly isn’t too difficult if you stay a bit organized. 👍 My tip for you: first insert the screws loosely so you can fit everything together accurately, and only tighten them properly at the end! This way, you can still make small adjustments if something isn’t perfectly aligned. Also, make sure to check the back panel twice since it’s crucial for stability! One more thing from my experience—a little tip: have a helper for positioning and wall mounting. It definitely makes the whole process much easier. Have fun with the assembly! 💪😊
Blavin
9 Aug 2023 13:04
To add for wall mounting: It is recommended to use the supplied metal anchors, as they are designed for optimal load capacity. For drywall (plasterboard) walls, special cavity anchors are essential to safely support the weight. Before drilling, carefully level the position of the cabinets using a spirit level to avoid adjustments later. Also, take care when attaching the door hinges to facilitate easier door alignment. Various IKEA models differ slightly in the drilling points, so it is important to follow the instructions. For easier assembly, it can help to assemble the lower cabinet units first and then attach and secure the upper modules.
Elodie
9 Aug 2023 14:18
Building Metod tall cabinets? Quite the adventure! 😄 Jokes aside, I think if you approach it like a small puzzle, assembling them feels much easier. Interestingly, I found that the key really is carefully reading the instructions – sounds like typical mom advice, but it’s true! The cabinets aren’t particularly heavy or difficult if you assemble them in modules and don’t try to attach everything at once. And a very important tip: check the floor carefully, as the furniture needs to stand level; otherwise, you’ll end up with a huge wobble later on. Also, a bit of excitement along the way doesn’t hurt – after all, who isn’t looking forward to a cool, sturdy kitchen? 🙃
Joachimfi
9 Aug 2023 17:36
nedagla schrieb:
First, screw the screws in loosely to fit everything precisely together, and only tighten everything properly at the end!
That sounds like a great tip, thanks! I was wondering whether to tighten the screws fully right away or only at the end. I’ll do it exactly like that.
I also have a question about wall mounting: How important is it to place all the cabinets fully assembled against the wall before starting to fasten them? Or can I attach the cabinets individually to the wall and then connect them together afterward?
I’m still uncertain about the safest and most practical way to handle this.
