Hello everyone, I have noticed that some screws in my Ikea Metod kitchen cabinets have become loose over time. This mainly affects the screws that hold the cabinet doors and the connecting fittings. I am now looking for an effective and long-lasting way to tighten or repair these loose screws without them coming loose again or damaging the material. What experiences have you had with this? Are there specific screws, adhesives, or methods that have proven successful? I would like to avoid having to remove the entire cabinet front or hiring professional help if possible. Thank you in advance!
Regarding the issue with Ikea Metod cabinets: These often use particleboard with a laminate layer, which tends to tear out the thread after repeatedly loosening screws. Therefore, a durable repair is essential. Recommendations: - Use a small amount of wood glue in the screw hole to improve holding strength - Alternatively, use larger or longer screws if structurally possible - Use threaded inserts to reinforce the material - Pay attention to the tightening torque to avoid cracking It is important that the screws and material are matched; otherwise, the problem will persist. Also, when working with the Metod system, always use the original connectors.
FeAndreas126 Jun 2022 14:38Hello Rubenjon, your issue is very common with the construction of Ikea Metod cabinets. For a durable repair of loose screws in these systems, I recommend the following step-by-step approach:
1. Completely remove the screws: First, fully unscrew the screws to carefully inspect the screw holes.
2. Check the condition of the material: Particleboard with a laminate surface tends to tear out, which is usually visible by swollen or damaged holes.
3. Repair the holes:
- Option A: Fill the hole with wood glue (preferably Ponal or a similar product) and allow it to cure thoroughly. After drying, carefully use a new, slightly thinner screw.
- Option B: If available, you can fill the hole with a suitable wood filler, let it harden, and then pre-drill a new hole.
- Option C: If you have good DIY skills, I also recommend using screw anchors or small threaded inserts in the wood.
4. Choose new screws: Slightly longer or thicker screws can provide better grip but should be compatible with the original connections.
5. Carefully screw in: Keep the torque very low to avoid causing further tearing.
6. Adjust the connections: Metod has connectors that use cam locking mechanisms to create firm pressure; it is worth checking this mechanism.
Finally, a question for you: Does the loosening occur mainly with the doors or more with the connections between the cabinet elements? Depending on this, the repair method can be adjusted.
Thank you very much for the detailed tips, @FeAndreas1. I am experiencing issues both with the door hinges and the connecting bolts of the modules. The doors are a bit loose, even after tightening the screws, and the modules themselves no longer fit together as firmly. Your suggestions regarding threaded inserts and wood glue sound interesting. Could you please provide more information about the threaded inserts? Which types are compatible with Ikea Metod, and how difficult is their installation? I would also like to know if it’s possible to replace the original screws with something sturdier without losing compatibility.
Additional information: Threaded inserts are excellent for restoring damaged or stripped holes in particleboard to create a stable screw sleeve again. For Ikea Metod cabinets, I usually use so-called threaded inserts (also known as insert nuts), which are screwed into pre-drilled holes. These distribute the torque better and prevent the hole from enlarging.
Procedure:
- Remove the old screw and the connecting element
- Slightly enlarge the hole (please observe the dimensions!)
- Carefully screw in the threaded insert using a special tool or by hand
- After curing, check the fit and then reinstall the screw
Important: Dimensions must be exact to avoid damaging the connection. Replacing the original screws with slightly larger ones that have the same head profile is usually unproblematic, but the length must be considered. For hinges, I recommend smaller increments, as the correct fit is essential for door function.
Procedure:
