ᐅ How do I fix loose screws in Ikea Metod cabinets?
Created on: 18 Dec 2023 09:13
NISINAU
Hello everyone, I have repeatedly encountered the problem with my Ikea Metod cabinets that the screws loosen, especially at the attachment points of the cabinet doors and shelves. I am interested in how you solve this issue in the long term and preferably without having to completely dismantle the cabinets. Is there a proven method to make the screws tight and, above all, load-bearing again? Should the screws be replaced, should special locking agents be used, or should the wood be treated in some way? I look forward to tips and experiences on repairing loose screws in Ikea Metod cabinets.
GALEO4
19 Dec 2023 08:14
Why do people always focus on the screws? In my opinion, the wood used in the Metod cabinets is generally quite fragile. Screws come loose because the material gives way, and over time the structure compromises. Tightening loose screws might be a symptom but does not solve the problem. It would be more effective to reinforce the construction beyond just the screws, for example with metal braces or stronger materials to support the corners. But yes, that requires extra effort, and Ikea probably doesn’t want us to do it that way. However, all this constant “loose screw here” won’t really fix the issue.
NISINAU
19 Dec 2023 09:05
uslis47 schrieb:
If the holes are already worn out, it helps to fill them with wood glue and small wood pieces or toothpick fragments so that the screw gets a better grip again.
Thank you for the detailed explanation; that sounds like the most practical solution. I’m also curious if you have experience using threaded inserts? Is the effort really worth it, or are they more of a specialized solution? I haven’t used threaded inserts for furniture so far, but I know they are commonly used in automotive and mechanical engineering.
U
uslis47
19 Dec 2023 10:37
Threaded inserts are definitely worthwhile if you want to make the piece of furniture secure for the long term and need to repeatedly remove screws. They are durable and prevent the wood from further tearing out. In practice, they are installed into pre-drilled holes—there are also versions with self-tapping threads. For Ikea Metod furniture, these inserts might even be the best solution if the wood can no longer hold. However, the downside is the installation effort and the need for suitable tools as well as an exact fit. For a few screws or temporary solutions, other methods like wood glue and toothpicks are often simpler and quicker.
Tobias
20 Dec 2023 07:47
The simplest method is to completely remove the screw, fill the hole with wood glue and toothpicks or wood chips, and let everything dry. Afterwards, reinsert the screw. This works very well and holds for a long time.
nolan
20 Dec 2023 09:23
I would add: For critical areas with a lot of movement, small thread lockers (liquid thread-locking adhesive) are also worthwhile. These prevent the screws from loosening repeatedly. This can be especially helpful with IKEA Metod, which uses thin panels, to extend the lifespan of the repair.
