ᐅ Secure and Practical Installation of Ikea Metod Wall Cabinets on Drywall Panels
Created on: 15 Oct 2023 08:23
blaleonardB
blaleonard15 Oct 2023 08:23Hello everyone, I am planning to install several Ikea Metod wall cabinets on a drywall (plasterboard) wall and want to make sure the mounting is both practical and long-lasting. Since these cabinets are quite heavy, I am wondering about the best way to securely attach them to a drywall wall, which is naturally not very load-bearing. What special anchors, reinforcements, or mounting techniques would you recommend to ensure the cabinets hold firmly without causing popping noises under even slight loads? I have read about metal brackets, wooden battens behind the drywall, and special heavy-duty anchors. What are your experiences and best practices for this kind of installation? Thanks in advance for your knowledgeable tips!
Hello blaleonard, I want to provide as detailed an answer as possible because the approach is crucial when dealing with drywall (gypsum board) walls. Basically, drywall alone has limited load-bearing capacity, so it is very important whether the wall cabinets can be mounted on a substructure or directly on the studs (wood or metal studs).
- First, I recommend using a stud finder to locate the studs behind the wall so you can screw directly into them.
- Ikea Metod cabinets quickly add 30-40 kg (66-88 lbs) on the wall when loaded; standard wall plugs are not sufficient for this. You will need special metal drywall anchors (toggle anchors or heavy-duty expansion anchors), but even these have limitations if you cannot attach to the studs.
- If that’s not possible, the safest solution is to install a wooden battens on the wall, securing them with long screws directly into the studs. Then you screw the cabinets onto these battens. This distributes the load much better and is significantly safer.
- Even better: mount a 12-18 mm (½–¾ inch) thick plywood or OSB panel onto the existing drywall, also screwed directly into the studs. You can then attach the wall cabinets to this panel.
In summary: without hitting the studs, it becomes problematic; with suitable heavy-duty anchors and reinforcement, it is manageable. Have you already located the studs? What load (weight including contents) do you expect approximately? That would help to advise you more precisely.
Hello blaleonard, I really appreciate that you take safety so seriously. I want to briefly explain the basics because there are often misunderstandings: drywall panels are primarily a covering and do not support significant loads. The load-bearing structure is provided by the metal or wooden studs behind them.
- It is not sufficient to screw only into the drywall panels or use anchors that just spin in the panel; this will not hold permanently.
- A proper mounting aid is a drywall bracket or a wooden batten that you attach directly to the studs.
- If you cannot screw directly into the studs, heavy-duty toggle bolts can help; these open up behind the panel. However, they often have a maximum load capacity of about 15 kg (33 lbs) per anchor.
- I also recommend, even with the Ikea Metod system, to mount cabinets using multiple attachment points rather than a single one to spread the weight.
If you like, I can also explain how to create a stable base for your cabinets on the drywall using a simple wooden board.
Don’t worry—with the right technique, it will work!
blaleonard15 Oct 2023 10:01Thanks for the quick and helpful responses!
@Domau0: I already have a rough idea of the metal stud positions since I built the wall myself. Unfortunately, they are not exactly behind the planned cabinet installation but are always slightly offset. Each cabinet can bear a load of up to 40 kg (88 lbs), depending on the contents.
@uslis47: Yes, I’m interested in the solution with a wooden board mounted on drywall so that I can flexibly add additional loads. It is important to me how to securely fix the wooden board to prevent damage to the drywall or warping of the wall over time.
Are there specific wood types, thicknesses, and fastening methods you would recommend? I would also like your advice on mounting the cabinets on this wooden board.
Hello blaleonard, I’m happy to answer with a brief guide on using wooden panel supports on drywall, specifically for mounting Ikea Metod wall cabinets.
1. Type of panel:
- It’s best to use a 15 mm (0.6 inch) thick plywood or OSB panel. These are sturdy and maintain their strength better even with some exposure to moisture. For example, a birch plywood panel.
2. Cutting to size:
- The panel should be roughly the size of the entire area where the cabinets will be mounted to distribute the weight evenly.
3. Securing the panel:
- Screw the wooden panel onto the metal or wood studs behind the drywall using long drywall screws at least 70 mm (2.8 inches) in length. The screws should be spaced about 15–20 cm (6–8 inches) apart.
- Additionally, use special drywall anchors (metal toggle bolts) at points where there are no studs to stabilize the panel.
4. Mounting the cabinets:
- Then drill the wall cabinets directly into the wooden panel, preferably with wood screws (e.g., chipboard screws). Screws hold better in wood than in drywall.
5. Tips:
- Check the wall area for any deformations before installation.
- Allow the wooden panel to slightly extend beyond the sides to avoid potential tension.
I have used this method with multiple clients – it is long-lasting and secure! If you need more details, feel free to ask.
1. Type of panel:
2. Cutting to size:
5. Tips:
Interesting approach with the wooden panel, but I have some doubts: Especially with relatively lightweight drywall partitions, even the additional weight of a plywood panel and the screws themselves can significantly weaken the wall.
One question: How large and heavy are the cabinets really? 40 kg (88 lbs) per cabinet sounds quite high, considering that Ikea Metod wall cabinets are often 30–50 cm (12–20 inches) deep and made from lighter materials.
Also, is there a way to reinforce the wall from the inside? For example, a substructure made of wood or metal directly behind the drywall, firmly attached to the building?
I see the risk that the wooden panels could create a kind of leverage on the wall, especially if the cabinets are mounted at multiple points. How can shear forces on the drywall be prevented, which could lead to cracks over time?
