ᐅ What should be considered when installing IKEA Metod wall cabinets?
Created on: 19 Jan 2023 08:17
RONWAYLONR
RONWAYLON19 Jan 2023 08:17Hello everyone, I am currently planning the installation of IKEA Metod wall cabinets in my kitchen and want to make sure I don’t overlook any important details. My specific question is: What should be considered when installing IKEA Metod wall cabinets, especially regarding the wall structure, proper anchoring, and alignment? Additionally, I am interested in which tools should ideally be available and if there are any special safety tips or precautions to prevent damage to the cabinets. I look forward to a detailed discussion to help ensure my project goes as smoothly as possible.
First, it is important to accurately identify the wall type (concrete, drywall, etc.), as this affects the choice of anchors. Metod cabinets require sturdy screws with suitable anchors, which are included in the package. Check the level during installation to avoid uneven results. Tools needed: cordless screwdriver, spirit level, drill.
Here is a brief guide for installing IKEA Metod wall cabinets:
- First, check the wall for load-bearing capacity, especially on lighter walls.
- Use a spirit level to mount the fixing rail perfectly horizontal.
- Choose screws and anchors appropriate for the wall type – for drywall, use special hollow wall anchors.
- Remove the cabinet doors before final installation to make the work easier and protect the surface.
- After installation, adjust the cabinets to keep consistent gaps.
Common mistakes include neglecting to secure the mounting rail properly and using insufficient fixing materials.
warrenka5719 Jan 2023 11:34I had some uncertainties myself when mounting my Metod cabinets. I found it especially important to take enough time and not rush, as that can quickly lead to frustration. If you have doubts about the wall structure, it's better to consult a professional. Safety comes first! And if you're not confident using your spirit level, double-check several times. That also helps you work more calmly.
In addition to the previous posts: The IKEA Metod wall cabinets are installed using a rail mounted to the wall, which has the advantage that you can easily adjust the cabinets afterward.
Make sure to mount the rail completely level – even slight deviations can cause problems with the doors. It is also important not to exceed the maximum load capacity of the cabinets and to regularly check the anchoring, especially if heavy items are stored inside.
As tools, I recommend a cordless drill, a spirit level, and also a rotary hammer if your wall is made of concrete or brick. If you have drywall, be sure to use appropriate hollow wall anchors.
If you have any questions, just ask.
For the precise installation of IKEA Metod wall cabinets, please consider the following:
- Accurately identify the type of wall and use appropriate fasteners.
- Strictly follow the assembly instructions, especially regarding the recommended screws and anchors.
- The wall bracket must be mounted perfectly level, using a spirit level; ideally, measure and align with a long level.
- Hang the cabinets lightly on the wall rail and align them from underneath against the wall; only then fully tighten the remaining screws.
- For drywall (plasterboard) walls, use only special hollow wall anchors to prevent safety risks caused by insufficient holding strength.
In summary: fully following the assembly instructions, choosing the right fasteners based on the wall type, and precise alignment ensure a secure and durable installation.
