ᐅ Secure and Practical Installation of Ikea Metod Wall Cabinets on Drywall Panels
Created on: 15 Oct 2023 08:23
blaleonard
Hello everyone, I am planning to install several Ikea Metod wall cabinets on a drywall (plasterboard) wall and want to make sure the mounting is both practical and long-lasting. Since these cabinets are quite heavy, I am wondering about the best way to securely attach them to a drywall wall, which is naturally not very load-bearing. What special anchors, reinforcements, or mounting techniques would you recommend to ensure the cabinets hold firmly without causing popping noises under even slight loads? I have read about metal brackets, wooden battens behind the drywall, and special heavy-duty anchors. What are your experiences and best practices for this kind of installation? Thanks in advance for your knowledgeable tips!
Nabla64
16 Oct 2023 09:05
blaleonard schrieb:
I have one more question: Is there an ideal or minimum number of screws per running meter of cross batten to consider?
Hello, I recommend at least 5-6 screws per running meter of cross batten, so roughly one screw every 15-20 cm (6-8 inches). This will securely hold the battens to the wall and minimize any warping or tilting.
Additionally, use screws with a good thread profile (self-drilling or wood thread) to ensure a secure grip in metal studs.
For the plywood sheet, follow a similar guideline: place screws every 15 to 20 cm (6-8 inches), making sure they are evenly spaced.
If you have any questions about screw selection or washers, feel free to ask!
faso31
16 Oct 2023 10:38
blaleonard schrieb:
I have one remaining question: Is there an ideal or minimum number of screws per running meter of the cross batten to consider?
I agree with the colleague; 5-6 screws per meter is a good standard. In critical areas where higher loads occur, I would even use 8 screws to better distribute the load.
By the way, you should also keep in mind that when cabinets are loaded, there is a downward tensile force as well as a lever effect caused by cantilevering. Therefore, it is worth reinforcing the lower hanging points of the cabinets or securing them with similar cross battens.
Another consideration would be to install a kind of "beam" underneath the cabinets, supported by the plywood panel, to spread the load over multiple points.
angel
16 Oct 2023 11:04
Hello blaleonard, I just want to add that you should also make sure not to place the screws too close to the edge of the panels to prevent tearing. A distance of at least 3 cm (1.2 inches) from the edge is ideal.
Also, when screwing the cabinets together, be sure the screws are long enough to fully engage in the plywood. This ensures maximum hold.
And finally: Before assembly, check all drill holes and, if necessary, countersink them so the screw heads sit flush and no deformations occur.
