ᐅ How can I accurately install Ikea Metod cabinets on uneven walls?
Created on: 2 May 2020 10:07
halit38
Hello community, I am currently planning to install Ikea Metod cabinets in my kitchen, but I have a specific problem: the walls are not straight, but noticeably uneven. My question is therefore: how can I precisely install Ikea Metod cabinets on uneven walls so that the furniture fits perfectly despite the wall irregularities and results in a clean finish? I would appreciate any tips on alignment, possibly necessary accessories, or installation methods to avoid mistakes and achieve the most professional result possible. Thank you in advance!
halit38 schrieb:
Can anyone recommend a very simple method if no laser level is available? Yes, you can use a spirit level together with a long straightedge (for example, a straight board) to work without a laser. Mark the height of the desired cabinet front at several points on the wall, then connect these points with a string or a straight batten – this creates a reference line. You then install the cabinets along this line, not directly on the original wall surface. Use small wooden wedges to fill the gap to the wall. Make sure to loosely attach all cabinets to the substructure first and only tighten them in the final step so any alignment errors can still be corrected.
halit38 schrieb:
Can anyone recommend a very simple method if no laser level is available? If you don’t have a professional level, you can work step-by-step using a long straight board and a small spirit level: mark the board at the desired height, place the spirit level on it, adjust the board until it is level, then mark the wall outline. Proceed this way in small sections to create a straight line. This method takes more time but is manageable for DIYers. It’s important to always work carefully and patiently, as small mistakes can add up quickly during cabinet installation. Also, don’t forget to secure all wedges firmly or carefully glue them so they don’t slip.
It is helpful to mark the wall with a pencil before installation to make any shifts and unevenness visible. This way, you can immediately see where the cabinets might be misaligned. For practical adjustments, mounting rails with adjustable elements are very effective in addition to wedges. A stable substructure makes later fine-tuning easier. I also recommend never fixing the cabinets directly to the wall permanently, but rather using small movable components that allow for readjustment.
Kyler10 schrieb:
You can use small wooden wedges to fill the gap to the wall. How stable are such wedges in the long term? Do I need to glue or screw them in place to prevent any movement? Are there preferred materials for this? Thanks for the advice!
halit38 schrieb:
How stable are such wedges in the long term? Do I need to glue or screw them to prevent any shifting? Wooden wedges are generally very stable, but I strongly recommend securing them to the substructure, for example with wood glue and small nails or screws. This is the only way to prevent the cabinets from shifting due to load or temperature/humidity changes. Plastic wedges can also be used, but they are less durable and often more slippery. It is important to fix all wedges only after alignment – in contrast, screws directly into the wall panel are not an option for wedges, as it is often thin and fragile. An excellent method is to lightly glue the wedges PLUS add slightly adjustable screws through the cabinet rail, which should not be tightened too much in case adjustments are needed. This gives you maximum stability and flexibility.
