ᐅ How can I make Ikea PAX wardrobes childproof?
Created on: 17 Jun 2022 19:07
O
oleksiibi
Hello everyone, I have several Ikea Pax wardrobes at home and am looking for ways to make them childproof. The goal is to secure the wardrobes so that young children cannot access contents that are dangerous or unsuitable for them, while at the same time not compromising the stability and functionality of the wardrobes. I’m interested in practical, proven solutions you know of—sliding locks, internal latches, special child safety devices, or other modifications. Are there also experiences with safely anchoring them to prevent tipping? Which products or methods have proven particularly effective in practice? Thanks in advance for your tips and recommendations!
neoren
17 Jun 2022 20:15
Simple principle: wall-mount all cabinets. Attach child safety locks either inside or outside, depending on the type of door. For sliding doors, magnetic locks are ideal. This way, you can usually keep children reliably out.
tyson51
17 Jun 2022 21:02
The stability of the Pax wardrobes should not be underestimated. Even with proper wall fastening, I would recommend not placing the wardrobes in areas where children might climb on them. For securing the wardrobe doors, child safety locks installed inside are better than adhesive locks applied externally, as they are less visible and less likely to encourage pulling.
baupau
18 Jun 2022 07:42
Magnetic child safety locks work very well with sliding doors; they are invisible from the outside and are difficult to open without the magnet. Internal bolts are practical for hinged doors and are available specifically for child safety purposes.
O
oleksiibi
18 Jun 2022 08:16
mopra42 schrieb:
Don’t forget wall anchors!
This is actually a very important point for me. How exactly do you recommend attaching the PAX wardrobes to the wall? I definitely don’t want them to tip over—especially since we have a very active toddler at home. Are the original wall anchors from Ikea sufficient, or is it better to use larger, stronger screws with additional wall plugs? If anyone has experience with this, please share.
laureo
18 Jun 2022 08:45
oleksiibi schrieb:
Are the original wall anchors from Ikea sufficient, or is it better to use larger, more robust screws with additional anchors?
The original wall anchors from Ikea are generally adequate, provided the wall is solid and suitable (e.g., concrete, solid brick). For drywall or if extra security is desired, stronger universal anchors and appropriate screws can be used. It is important to place them correctly in multiple points and ensure the screws are deeply and securely fixed. If there is any doubt about the wall quality, it is better to use specialized heavy-duty anchors or consult a professional for advice.
INGRID34
18 Jun 2022 09:05
I have tried both options: the original Ikea sets are sufficient for standard walls, but for drywall you should definitely use special anchors. The number of fixing points is also important – better to have more than fewer.
