ᐅ How can I accurately install Ikea Metod cabinets on uneven walls?
Created on: 2 May 2020 10:07
halit38
halit38
2 May 2020 10:07
Hello community, I am currently planning to install Ikea Metod cabinets in my kitchen, but I have a specific problem: the walls are not straight, but noticeably uneven. My question is therefore: how can I precisely install Ikea Metod cabinets on uneven walls so that the furniture fits perfectly despite the wall irregularities and results in a clean finish? I would appreciate any tips on alignment, possibly necessary accessories, or installation methods to avoid mistakes and achieve the most professional result possible. Thank you in advance!
Kyler10
2 May 2020 10:39
Hello halit38, with crooked walls the main goal is not to align the cabinets directly to the wall but to use a reference line that you establish beforehand. This means: - Check the wall irregularities using a long spirit level or a laser level and mark the key points. - Draw a straight reference line parallel to the cabinet front height to align the cabinets along it. - Use adjustable mounting rails or battens as a base during installation to compensate for unevenness. - You can adapt the cabinets to the wall using wedges or spacers to make them appear flush. - The fronts should above all be installed flush with each other; visual consistency is the top priority here. If necessary, you will need to customize baseboards or trim individually, especially with larger wall deviations. This way you avoid gaps and an uneven overall appearance.
KUDAISY
2 May 2020 11:15
In addition to Kyler10: I would recommend planning the installation in three phases. 1. Wall preparation: As Kyler10 mentioned, it is important to precisely measure the wall to identify any major irregularities. 2. Construction of the leveling framework: Often, wooden battens or an adjustable metal substructure are suitable, to which the Metod carcasses are attached. 3. Fine adjustment: After securing the cabinets, they are aligned using height-adjustable feet and wedges so that the doors close perfectly and are evenly aligned. Common mistakes include mounting directly onto an uneven wall without any intermediate layer or attaching fronts crookedly. The biggest challenges often arise from the lack of flexibility in depth adjustment. Here, spacer blocks or panels that need to be custom-cut can help. I am happy to provide more detailed advice on implementation if needed.
NoValentin
2 May 2020 11:44
In short: A straight mounting strip is essential. Always align cabinets to this strip, not to the wall. Use adjustable feet and shims for leveling.
PLOMA
2 May 2020 13:00
Hello halit38, to work precisely with uneven walls, here is a more detailed approach based on years of experience:
- First, use a laser level or a very long spirit level to measure the wall accurately at several heights and define the distances to the planned front line. Mark this reference line, which runs parallel to the desired cabinet front.
- Next, build a substructure. I recommend using wooden battens that you mount on the wall and adjust so that they are exactly aligned with the reference line. Note: These battens must be fixed with enough distance from the wall to compensate for irregularities.
- The Metod carcasses are then screwed to this substructure, ensuring a very straight alignment and preventing stress caused by the uneven wall.
- To also compensate for depth differences, I suggest using spacer battens or custom wood wedges between the carcass and the wall.
- The height-adjustable feet are essential for final fine-tuning so that doors close properly and baseboards fit flush.
- Trims and cover panels also need to be adapted individually, for example by sanding in cases of significant wall curvature.
Another recommendation is to use special anchors and screws that remain adjustable in case you want to make later adjustments.
What type of walls do you have (brick, drywall, concrete)? Sometimes the fastening options vary significantly depending on the substrate.
halit38
2 May 2020 13:45
PLOMA schrieb:
What type of walls do you have (brick, drywall, concrete)? Sometimes the mounting options vary significantly depending on the substrate.
The walls are mainly brick, although somewhat old and no longer perfectly straight, with small uneven spots in some areas. I don’t have any specialized tools except a spirit level and common tools for furniture assembly. Can anyone recommend a very simple method in case a laser level is not available?
