ᐅ What is the best way to install IKEA Metod cabinets on sloped ceilings?
Created on: 16 Jul 2020 08:23
Klodeniz63
I’m planning to install new IKEA Metod kitchen cabinets in my attic. The challenge is the sloping ceiling above the countertop, which slopes down on one side. Now I’m faced with the task of adapting the cabinets accordingly, since standard cabinets don’t fit well in that space.
I’m interested in how you have handled similarly challenging sloped ceilings in your rooms with IKEA Metod cabinets. Are there specific tips for cutting or adjusting the modules? Do you use shelves under the sloped ceiling, incorporate support beams or modifications? Or do you work with custom-made solutions to fit the cabinets smoothly into the slope?
What are your best advice and experiences regarding installation, stability, and appearance of Metod cabinets under sloped ceilings? I want to avoid the cabinets looking too cramped or ending up unstable.
Thanks for your tips!
Klodeniz63
16 Jul 2020 11:02
noge58 schrieb:
For the upper finish, I used special glass panels that can also be custom-made
Is this a specific Metod extension, or did you purchase these glass panels externally? And how did you fix them in place? Would something like this even work on my slope with about a 30-degree incline, or is it more suitable for shallower angles?
fiman
16 Jul 2020 12:24
Take measurements, adjust the back panels, and bevel the top cabinets. Then add a cover panel or a finishing strip. That’s all you need.
BARSAN
16 Jul 2020 12:47
Measure accurately and, if necessary, reduce the cabinet depths to avoid issues with the sloping roof. Cut yourself or use a cutting service.
Klodeniz63
16 Jul 2020 14:11
fiman schrieb:
Take measurements, adjust the back panels, and bevel the top cabinet boxes. Then add a filler panel or end strip.
Does Metod have an official solution or recommendation from IKEA for sloped ceilings? So far, I’ve only found standard cabinets but no special angled cabinets. Do they perhaps improvise using filler panels?
Linavin
16 Jul 2020 14:35
Unfortunately, IKEA does not offer Metod cabinets specifically designed for sloped ceilings, which can sometimes feel a bit limiting.
The modules should be seen as a base, with custom solutions added as needed, for example, self-made panels or covers that are precisely adapted to the slope.
Klodeniz63 schrieb:
Is there an official solution or recommendation from IKEA for sloped ceilings with Metod?
No, there isn’t – which is why creative DIY solutions are usually necessary.
I also recommend not underestimating stability. The cabinets are often only wall-mounted, and sloped ceilings can introduce additional forces.
Joe52
16 Jul 2020 15:08
Adjusting for roof slopes is really tricky – I know the feeling of standing in front of the components with an uncertain gut feeling!
What helped me:
- If possible, plan a complex installation first before starting
- For example, use a drywall partition or wooden panels as a base to which the cabinets can be attached
- This stabilizes the whole setup and allows more flexibility when cutting
It’s important not to lose courage – it will definitely turn out better than expected!
