ᐅ How can I securely install Ikea Metod cabinets on uneven or sloping walls?
Created on: 26 Feb 2021 08:17
teojamie51
teojamie51
26 Feb 2021 08:17
Good morning everyone, I plan to install Ikea Metod kitchen cabinets in my apartment, but I’m facing the problem that the walls here are quite uneven. The irregularities and slopes are sometimes more than 2 cm (0.8 inches) over a length of 2 meters (6.6 feet). How can I still mount the Metod cabinets securely and level so that they stand safely and straight, without causing any future structural or functional issues? I’m open to tips on leveling, fastening to the wall, and possible alternative solutions if the Ikea mounting system has limitations in this regard. Thanks in advance for your opinions and experiences!
BARSAN
26 Feb 2021 08:29
It is best to use a mounting strip attached directly to the wall. You can compensate for unevenness there with washers or wood shavings. The cabinets are then hung on the strip, ensuring they sit stable and level.
GLAEL
26 Feb 2021 08:45
I would recommend measuring the walls carefully beforehand and filling any gaps with expanding foam or joint sealant. For additional stability, cabinet connectors between the modules can also be helpful.
LOJOPAR
26 Feb 2021 09:01
Hello teojamie51, I’m happy to help you here. When dealing with uneven walls, there are some proven methods to install Metod cabinets neatly and securely:
- First, attach a sturdy mounting rail to the wall. You can align this rail horizontally, either perfectly level or along the desired line.
- To compensate for irregularities, use self-adhesive spacer pads, wooden wedges, or appropriate shims.
- The cabinets are then hung on this rail. This way, the system is supported by a single strong element and can still be adjusted later.
- When connecting the cabinets to each other, make sure to maintain even side gaps and proper alignment.
- It often helps to use a spirit level and, if available, a laser level beforehand to position the mounting rail precisely.
One more tip: If the wall curves significantly inward, ensure a stress-free installation so the cabinets do not warp.
In summary: a mounting rail combined with adjustment measures is usually the safest and most stable approach. Good luck!
teojamie51
26 Feb 2021 09:20
LOJOPAR schrieb:
The cabinets will then be hung on this rail. This way, the system is supported by a single load-bearing element and can still be adjusted later.
That sounds good so far. So with the mounting rail, you can level it before hanging and make adjustments afterwards if needed. Do you think the rail should be fixed with several anchors, or are just a few enough? What is the best approach for measuring when the wall is uneven at different points?
SauDietmar
26 Feb 2021 09:42
For fastening the mounting rail: the longer and heavier the cabinets, the more anchors you will need. For Ikea Metod, a good rule of thumb is to use at least 3 anchors per 60 cm (24 inches) of cabinet width.
For measuring:
- It’s best to use a spirit level or, even better, a laser level to mark an exactly straight line.
- On a slanted wall, roughly mark the heights for the bottom edge of the cabinets first.
- Then extend the line along the wall before attaching the rail.
- If the wall is very uneven, you can use small shims underneath to keep the rail at a consistent height.
Also, make sure to consider the type of wall – for example, concrete requires completely different anchors than drywall (plasterboard).
