ᐅ How can I flexibly adapt IKEA Metod cabinets during renovations?
Created on: 16 Aug 2021 08:42
V
Vicenzo
V
Vicenzo
16 Aug 2021 08:42
Good morning everyone, I am facing the challenge of making my kitchen flexible using IKEA Metod cabinets as part of a major renovation. Specifically, I am looking for ways and tips on how to modify the Metod cabinets in a straightforward and modular way so that they can be easily reconfigured or expanded in the future without having to buy completely new furniture. Does anyone have experience, for example, with changing fronts, interior drawers, or cabinet dimensions? What tricks help to adapt the cabinets to new room conditions or to extend existing kitchen layouts? I would appreciate any advice on compatible accessories, useful additions, and also the limitations of the system.
AUSTINREN
16 Aug 2021 09:17
The flexibility of the IKEA Metod cabinets mainly comes from their modular system. The cabinets have a standard size, which makes replacement and expansion easier. To adapt the cabinets during renovations, I recommend the following points:
- Replaceable fronts and handles allow visual changes without much effort.
- Internal drawers and flexible compartments can be added modularly to customize storage space.
- There are various heights (40, 60, 80 cm (16, 24, 32 inches)) that can be used strategically to cover different room elements.
- When relocating the kitchen, it is often sensible to remove the upper front and only move or reassemble the cabinet carcass.
However, note that the depth of 60 cm (24 inches) is a standard, so adjustments become more complicated with unusual room depths.
Tevin
16 Aug 2021 09:39
Hello Vicenzo, I fully agree with AUSTINREN and would like to add to that. An important factor for flexibility is to plan with modular elements in mind – that means more smaller cabinets instead of fewer larger ones. This makes future remodeling easier.
Additionally:
- You can secure individual cabinet units with connecting fittings from IKEA or third-party suppliers, which allows for easier disassembly.
- The Metod system offers frames designed for later expansions.
- You can often change door swing directions by repositioning the hinges.
If you plan to change kitchen fronts frequently, it’s worthwhile to use front mounting profiles or magnetic holders. This way, you can quickly update the look.
V
Vicenzo
16 Aug 2021 10:10
AUSTINREN schrieb:
There are different heights (40cm (16 inches), 60cm (24 inches), 80cm (31 inches)) that can be used strategically to cover different room elements.
Thanks for the note on the heights; that’s a good approach. I’m curious if anyone has practical experience with how difficult it is to modify a base cabinet from, for example, 80cm (31 inches) to 60cm (24 inches), or vice versa—that is, adjusting the carcass dimensions. Do you need to replace the entire modules, or can parts be modified?
Also, what about the countertop level? Are worktops easy to replace over a longer period?
DULIS
16 Aug 2021 10:33
The carcasses are solidly constructed. You usually replace them entirely. Heights vary depending on the base unit and back panel. Countertops can be easily replaced, as this typically involves screwing or clamping.
semuneo
16 Aug 2021 11:01
I did exactly that a year ago: rearranged the kitchen and partially regrouped the Metod cabinets. For me, it went smoothly because I had good documentation and the cabinets are only screwed together. I only had to buy a few fronts again because the colors didn’t match.
When disassembling and reassembling, you need to handle the screws carefully, or they can break easily. The system is very flexible but can’t be moved back and forth indefinitely – after a while, you notice that the wooden parts lose stability.
