ᐅ How do I build IKEA Metod cabinets with sliding doors for modern living spaces?
Created on: 12 Jun 2024 09:11
O
OLEK45Hello everyone,
I am planning to install Ikea Metod kitchen or wall cabinets with sliding doors that I want to integrate into a modern living space. My question is: how can I build the Ikea Metod cabinets with sliding doors so that they are both stable and functional, while also visually fitting into a contemporary interior and handling everyday use with smooth sliding mechanisms? I am especially interested in how to properly attach the sliding doors, which additional parts or modifications are useful, and how to make the best use of the space behind the doors. Are there any experiences or tips regarding combinations with specific materials, such as glass or wood fronts? I look forward to your practical advice!
For sliding doors, you need special track systems that Ikea does not usually provide. Make sure to use sturdy upper and lower tracks with rollers. Doors are typically ideal at 16 mm (5/8 inch) thickness. Additional features like soft-close make operation easier. Also, ask whether you should mount the cabinets at baseboard height or directly to the wall, as this improves stability.
Hello and welcome to the thread! I really like your approach of using Metod cabinet units with sliding doors for modern spaces. Traditional cabinets are often fitted with hinged doors, but sliding doors save space and create a clean look. It’s important, especially, to align the tracks precisely to prevent the doors from sticking. For contemporary living concepts, glass fronts in matte or frosted finishes work particularly well, giving the room a light, airy feel. You can also experiment with wood finishes to add warmth.
Regarding installation: Make sure to securely fix the cabinets, for example, by mounting them to the wall, and use a spirit level and measuring tape carefully. If you need to get roller or track systems, I recommend those designed specifically for furniture and that offer soft-close functionality.
What location are you planning to install them in – kitchen, living room, or hallway?
Kinbu schrieb:
What is the intended location – kitchen, living room, or hallway? Thank you for the kind follow-up! The cabinets are mainly planned for the open-plan living and dining area, where they will have some kitchen elements but also serve as storage and room dividers. The idea is for the sliding doors to move smoothly and discreetly, without taking up too much space or disrupting the clean lines.
The floor will be very level, and the rooms are rather large, so stability when opening and closing the doors is really important. I want to avoid the doors feeling stiff or operating unevenly.
Hello OLEK45,
for such a well-thought-out project, here is a step-by-step recommendation for building your Ikea Metod cabinets with sliding doors in a modern living concept:
- Preparation: Assemble all cabinet components completely and adjust them properly before you start installing the sliding door systems.
- Track systems: Purchase a sturdy track set with double rollers at the top and bottom. The bottom must always have running rollers to ensure the door runs smoothly and stays stable.
- Door selection: Pay attention to the thickness of the cabinet doors. Metod doors are usually 16 mm (0.6 inches) thick, which is ideal for the track systems.
- Fixing: Securely mount the cabinets to the wall to avoid any wobbling during use.
- Door installation: Carefully use the included adjustment screws during installation to ensure the doors run perfectly parallel.
- Style: Glass fronts in smoky or white frosted finishes offer a modern, minimalist flair. Alternatively, veneered wood fronts create a warm atmosphere.
Common mistakes:
- Installing the track system not perfectly horizontal – this causes difficulty in sliding.
- Overloading the doors once they are installed.
- Missing end stops on the tracks.
Overall, make sure to allow enough time for a proper setup.
Common mistakes:
I can only agree with Nabla64. Especially in open spaces, it is important to align sliding doors precisely and install them securely. A quick tip: pay attention to the tolerances with Ikea Metod systems. They are generally good, but when installing sliding door systems, you should definitely use a spirit level to avoid misalignments and problem areas.
The door fixtures should also be of high quality. If you choose glass fronts, the glass must also meet sufficient safety standards.
If you like, I can also give you tips on how to optimize the interior organization of the cabinets for living areas rather than kitchens.
