ᐅ How can I flexibly adapt IKEA Metod cabinets during renovations?
Created on: 16 Aug 2021 08:42
V
Vicenzo
Good morning everyone, I am facing the challenge of making my kitchen flexible using IKEA Metod cabinets as part of a major renovation. Specifically, I am looking for ways and tips on how to modify the Metod cabinets in a straightforward and modular way so that they can be easily reconfigured or expanded in the future without having to buy completely new furniture. Does anyone have experience, for example, with changing fronts, interior drawers, or cabinet dimensions? What tricks help to adapt the cabinets to new room conditions or to extend existing kitchen layouts? I would appreciate any advice on compatible accessories, useful additions, and also the limitations of the system.
Naomige
16 Aug 2021 11:28
Accessories are also important. I find the interior drawers from Metod very practical because they are easy to install and create a lot of storage space. If you want to stay flexible during renovation, opt for adjustable shelves that can be easily repositioned.
You can also make use of the inside of cabinet doors— for example, with hooks or small baskets. This can be easily customized and increases functionality without needing to access the cabinet carcasses.
GALEO4
16 Aug 2021 12:00
semuneo schrieb:
The system is very flexible but cannot be moved back and forth indefinitely
This is exactly the critical point for me. Flexibility is great, but Metod has clear limits, especially if you plan to remodel frequently. The connections are not designed to be assembled and disassembled repeatedly over a long period. In my opinion, IKEA misses out on potential here, as the market demands more modular, truly reusable furniture.
For frequent renovations, I would rather rely on modular designs from other manufacturers.
V
Vicenzo
16 Aug 2021 12:23
GALEO4 schrieb:
Metod has clear limitations, especially if you plan to remodel frequently.
That’s important to know, thank you. For the planned renovation, I’m only expecting occasional adjustments, not constant remodeling. If anyone has tips on how to reinforce the stability of the connections for repeated remodeling, I’d be glad to hear them.
I assume simple replacements of screws with different ones or reinforcements at the corners are possible?
Dopoki
16 Aug 2021 12:56
For reinforcement, I recommend using special corner connectors and metal brackets from a hardware store that can be installed inside the carcasses. Additionally, extra screws along the edges can help sometimes without damaging the surface.
For more flexibility without compromise, you can also use easily detachable connections like Minifix or Lamello, provided the Metod holes are compatible.
Tevin
16 Aug 2021 13:29
Vicenzo, regarding your question about countertops: Metod is typically designed for standard countertops with a thickness of 2.8 cm (1.1 inches). These can be secured to the cabinet frame from underneath using special screws and are relatively easy to remove during disassembly.
When remodeling, you can therefore replace the countertop quite easily. You might need to make adjustments to the backsplash or where it meets the wall tiles – but this depends on the tradesperson.
Regarding the fronts: IKEA often offers different series of fronts that fit the same dimensions. Custom fronts sometimes need adjustment as well, due to standardized hole distances.
meGreg
17 Aug 2021 07:18
Hello everyone, I just wanted to share something fun: recently, I almost completely rebuilt a Metod cabinet after accidentally damaging one during a move. It actually went much better than expected, almost like Lego for adults!
Of course, the boards aren’t quite as sturdy as a stone fortress, but they work great for flexible renovations. If you can swap out the doors and handles, you basically get a new kitchen without any stress.
If anyone wants to take a more relaxed approach: try mixing Metod cabinet boxes with different handles and fronts – it often looks fresher than you might think!
