ᐅ Quickly Modify and Adapt IKEA Metod Cabinets During Renovations
Created on: 27 Apr 2024 19:12
narkiHello everyone,
I am currently planning a kitchen renovation and considering how to modify or adapt my IKEA Metod cabinets as flexibly and quickly as possible. Ideally, the cabinets should be easy to adjust to changing room conditions since I expect to rearrange the layout quite often. Does anyone have experience with modifying IKEA Metod cabinets so that their height or depth can be adjusted quickly, for example?
I am especially interested in tips regarding the following points:
- Which modules or components are best suited for frequent modifications?
- Are there any tricks to design the cabinet doors or interior fittings so they can easily expand or adapt?
- How can stability be ensured after multiple modifications?
Looking forward to any experiences and practical advice!
narki schrieb:
Does anyone have experience with modifying IKEA Metod cabinets so that the height or depth can be quickly adjusted, for example?I find this an interesting question. I have wondered how flexible the Metod system’s construction really is. From my experience, the standard carcasses have fixed dimensions that can only be changed with considerable effort—such as cutting the panels yourself, which I wouldn’t recommend for routine modifications.
Are there reliable tips on how to technically achieve flexibility without compromising stability and durability? Simply “cutting neatly” is, in my opinion, not a long-term solution. I would rather imagine there are modular components that can be added or swapped instead.
Could corner solutions or specific post elements be the key here?
Hello narki, I have several Metod cabinets myself in a rental apartment that I have had to remodel twice. Basically, the system is quite flexible if you work with the basic units (standard carcasses of various sizes) and simply reassemble them.
- Height adjustments are usually only possible by changing the feet or stacking cabinets (so rather rare).
- For the depth, you often only have a choice between standard depths (37 cm (15 inches), 60 cm (24 inches), 80 cm (31 inches)). The only option here is to buy different carcasses.
- Doors are easy to swap and you can even use double doors, which create more space.
- Interior fittings like drawers and shelves are very modular and easy to modify.
I would recommend not cutting too much into the carcasses but rather working with the available dimensions. Stability is otherwise very good, and the connectors are robust.
May I add something?
A tip for quick adjustments with Metod: use cabinets with adjustable feet and place them on variable supports – this way, you can better compensate for height differences without having to rebuild everything.
Also, the fronts are easy to swap out. I have replaced the doors several times with different designs without having to rebuild the entire cabinet.
You don’t need to remove thousands of screws – often it’s enough to make small adjustments to the sides or the back panel. IKEA also offers many compatible accessories for this, such as corner connectors and flexible internal components.
For depth adjustments: if possible, place cabinets side by side instead of stacking them. This way, you can create more space without the need for trimming.
Metod is basically stable if you stick to the standard dimensions. For quick modifications:
- Doors and drawers can be easily detached and mounted elsewhere.
- The carcasses can be stacked or placed side by side.
- Custom cuts are available for individual dimensions, but they are not intended for quick changes.
Hey narki,
a Metod system is a bit like a LEGO set for adults – you build, swap parts, experiment, and get creative. 😉
When making quick changes, it helps if you stay flexible from the start – so rather choose several smaller modules instead of one large cabinet. This way, you can move or adjust individual elements without risking the whole unit collapsing.
For doors and internal drawers: just remove the doors, pull out the inner drawer, put it in, done. No expert skills required. Admittedly, with careful planning it’s more enjoyable, but that’s exactly what these systems are designed for – easy peasy.
For example, I once improvised a cabinet in the living room, rebuilt and reorganized it in about 45 minutes – super flexible and fast!
