ᐅ Ikea Metod: How can I efficiently assemble kitchen cabinets during renovations?
Created on: 19 Feb 2022 09:12
Boguel
Boguel
19 Feb 2022 09:12
I am currently planning a kitchen renovation and want to use furniture from the Ikea Metod system. My question to the community is: What is the most efficient way to assemble kitchen furniture during renovations like this?
I am particularly interested in:
- How can I best plan the installation in advance to save time?
- Are there proven steps or tools that make assembly easier?
- Are there specific points to consider during renovations to avoid rework later on?
I have some experience with furniture assembly but want to avoid mistakes and find the best approach.
Thanks in advance for your tips!
tra_nina
19 Feb 2022 09:45
Hello Boguel,
Regarding your question about efficiently assembling IKEA Metod kitchen cabinets during renovations, I recommend the following structured approach:
- Take precise measurements of the room beforehand, including corners and niches, to plan the cabinet installation accurately.
- Create an assembly plan in a logical order (install cabinets from top to bottom, left to right).
- Sort all parts and check for completeness before starting the assembly.
- Dismantle the old furniture as early as possible and thoroughly clean the wall and floor surfaces.
- In renovation projects, watch out for any unevenness and level these areas before installation.
- Use clamps or cabinet clamps for more stable work.
This will save you time and reduce the risk of assembly errors.
If you like, I can also recommend professional systems that make assembling IKEA kitchens faster.
praWarre69
19 Feb 2022 10:23
Hi Boguel,
I can only agree with tra_nina and add: A well-planned preparation makes all the difference! I once assembled my Metod kitchen in a weekend, and honestly – avoiding all the chaotic stuff is worth its weight in gold.
Important: Take the time to organize all screws, dowels, and fittings by type in small boxes. Trust me, it saves hours of searching.
And if you’re not very handy, better grab someone to help you – working together makes everything much more relaxed.
But don’t rush yourself. Rome wasn’t built in a day, and your kitchen will thank you with a great final result.
leguson
19 Feb 2022 11:01
First, assemble all cabinets completely before installing the countertop. Use a spirit level to ensure proper alignment. Tighten the cam connectors securely to maintain stability.
giabau
19 Feb 2022 13:35
I would like to add my experience, as assembling IKEA Metod kitchen cabinets during renovations involves some specific challenges.
1. Preparation:
- Measure rooms thoroughly and mark the exact positions of the cabinets.
- Check walls and floor levels for unevenness and correct them, for example, with leveling compounds.
2. Coordination of steps:
- Start with the base cabinets, align them precisely, and lock the units together.
- Then install the wall cabinets, as they can get in the way if installed too early.
3. Tools:
- Use a cordless drill with a torque limiter.
- A small spirit level and measuring tape, plus clamps for securing parts.
4. Common pitfalls:
- Avoid overtightening screws to prevent damage to the material.
- Remove edges and protective films only at the very end.
Summary: A well-structured order of work and careful preparation significantly reduce rework. During renovations, it is also helpful to use protective mats on the floor to avoid scratches.
I hope this helps!
Lidan56
20 Feb 2022 08:14
Definitely start by unpacking and sorting all the parts. Avoid interruptions during assembly. Work from the bottom up and regularly check the alignment.
