ᐅ Ikea Metod: How do I properly attach doors with recessed handles?
Created on: 12 Jan 2015 09:17
GobaliHello everyone, I recently assembled an Ikea Metod kitchen system and am now facing the challenge of properly attaching the doors with integrated grip handles.
The doors themselves are quite heavy, and I want to avoid them warping over time or putting strain on the hinges. Additionally, the assembly instructions are quite limited when it comes to this specific door type.
My specific questions are:
- What fastening materials are best suited for the handles to ensure secure hold and stability?
- Are there any special screwing techniques or spacers I should consider to make sure the door fits flush and without play?
- How can I prevent damage to the grip recess when opening or closing the door?
If anyone has personal experience with these doors or tips on common issues, I would be very grateful!
Hello, you should securely screw the doors using the supplied concealed hinges. For the recessed handles, you usually do not need to use additional screws, as they are typically pre-assembled and sturdy enough.
It is important not to tighten the screws too much to avoid damaging the wood. Adjust the hinges according to the instructions so that the doors close properly.
FABIAN_DEO12 Jan 2015 10:05Hello Gobali,
your question is very good; these doors with recessed handles do require special care during installation. I have installed several kitchens with Metod fronts and can explain the following points in detail:
- Fastening materials:
Ikea usually provides suitable screws for the hinges. For the doors themselves, screws that are not too long are used to avoid pushing through the door. The recessed handles are often made of MDF or coated material, so a steady hand is important during installation since the recess does not allow for additional fastening.
- Screwing technique & spacers:
It is recommended to first loosely attach all hinges, then hang the door onto the cabinet. After that, you can gradually tighten the screws and fine-tune the position using the adjustment screws on the cup hinges. Use a level or measuring tools to ensure no edges protrude.
- Protection of the recessed handle:
To prevent damage, use soft padding or a cloth when working with a screwdriver or cordless drill directly on the recess. Another tip: use a screwdriver with torque limitation or set the cordless drill to a gentle setting. The cutouts are delicate, and too much pressure often leads to cracks or dents.
A small digression on common sources of errors:
- Over-tightened screws can cause tension
- Uneven adjustment worsens the opening feel
- Missing spacers can cause improper weight distribution on heavy doors
I am happy to help with further questions or details!
Great that you’re asking this question! I love the Metod systems!!
I had the same uncertainties at first, but once you adjust the hinges correctly, everything works perfectly!
Remember to tighten the screws more by feel rather than fully tightening them – this protects the material and the recessed handle!
Good luck with the rest of your build, it’s going to be great!
Hello Gobali,
I would like to add some basic tips that might help you when installing doors with recessed handles:
First: The handles are actually cutouts in the door, so you don’t need to attach anything additional there. The main load is carried by the hinges.
Second: Attach the hinges to the door edges first, then hang the doors onto the cabinet carcass. Hinges usually allow for height and lateral adjustment, which lets you align the door perfectly.
Third: Make sure to screw into the designated pre-drilled holes and avoid over-tightening, as this can cause the edges of the recessed handle to break or the wood to splinter.
If you use a cordless drill, set the torque as low as possible. It’s better to tighten the screws gradually in several steps than to overtighten them all at once.
I hope this helps you.
FABIAN_DEO schrieb:
A brief note on common sources of errors:This is exactly where I often see the problem: a lack of patience during alignment.
I always wonder whether Ikea’s system is deliberately designed for quick self-assembly, accepting certain compromises in durability.
The mention of spacers is interesting, but I often find these small aids missing in the supplied kits, which would help ensure an even fit.
Has anyone here ever retrofitted or modified such spacers afterward?
