ᐅ Is it possible to use different handles on Ikea Metod cabinets?
Created on: 17 Aug 2015 08:23
jote38Hello everyone, I am currently planning to purchase several IKEA Metod kitchen cabinets and already have a pretty clear design concept. However, I am wondering if it is possible to use handles on the Metod cabinets that are not from IKEA. Specifically, I am interested in the following:
- Are there any specific technical requirements for handle installation on Metod, such as hole spacing or screw size?
- Are other handles compatible without modifications, or will I need to drill new holes?
- How does using custom/larger or smaller handles affect the stability and appearance?
I would prefer not to use the original IKEA handles, as I want to create a more personalized look. Does anyone have experience with this or technical advice on what to consider? Thanks in advance!
Hello jote38, your question is very good and important when making such modifications. Basically:
- The Metod cabinet doors usually have a standardized hole spacing for handles. This is typically 128 mm or 160 mm (5 inches or 6.3 inches), as specified by IKEA.
- Other handles can be used as long as the hole spacing matches or is drilled accordingly.
- If you need to drill new holes, clean and straight drilling is important to avoid weakening the door panel.
- IKEA generally uses M4 screws to attach the handles, which you should consider when choosing replacement handles.
One tip: It’s best to measure an existing handle or use the current handle as a template to avoid drilling errors. If you want to use larger or heavier handles, make sure the screws are long enough and do not damage the door.
In summary: Yes, you can use different handles, but you need to pay attention to the hole spacing and screw size and possibly drill new holes.
mifusau schrieb:
Metod cabinet doors usually have standardized hole spacing for handles. This is typically 128 mm (5 inches) or 160 mm (6 1/4 inches), as specified by IKEA.That is correct, and I’d like to elaborate a bit. Metod doors generally come with two common hole spacing options, depending on the door size. Smaller doors usually use 128 mm (5 inches), while larger ones often have 160 mm (6 1/4 inches). If you want to use different handles, I recommend carefully examining and measuring the door first.
If you choose handles with a different hole spacing, this is certainly possible, but only if you are prepared to drill new holes. This means:
- Use a drill bit with a small diameter and work precisely to keep the hole pattern neat.
- Measure the hole spacing accurately (preferably several times) to avoid misdrilling or damaging the door material.
- Black painted or veneered doors require extra caution, as any drilling mistakes will be very noticeable.
Regarding screw size, compatible screws should be used (usually M4). Depending on the handle, you might need longer screws if the handle is thicker.
Also important: Some handles are designed to have minimal impact on the door’s weight (for example, based on material and mounting). Very heavy metal handles, especially on large doors, can create stresses that may affect the hinges over time.
On the topic of aesthetics: Different handles can fit very well depending on the overall kitchen design. Some users combine matte brushed metal handles with white doors, while others opt for wood or leather-look finishes.
If you like, you can share your door measurements, and I can help suggest which handles available on the market would fit best.
leebi7 schrieb:
That’s correct, I’d like to explain that in more detail.Thank you for the detailed information. At the moment, I have doors that are 40cm (15.7 inches) wide, and those usually have 160mm (6.3 inches) hole distances, right?
mifusau schrieb:
If you need to drill additional holes, clean and straight drilling is important to avoid weakening the door leaf.Could you or someone else briefly explain the best way to proceed when drilling new holes here? Especially with such thin doors, I’m a bit concerned that the door might crack or warp.
jote38 schrieb:
Could you or others briefly explain the best approach when it comes to drilling new holes here? Especially with such thin doors, I’m a bit worried the door might chip or warp.Very good question. I recommend:
- Use a drill bit suitable for both metal and wood (e.g., an HSS bit if the door is painted and veneered).
- Drill at a low speed to avoid heat buildup.
- Place a piece of painter’s tape or masking tape over the drilling spot beforehand. This reduces chipping on the veneer.
- Drill slowly and with light pressure; let the drill bit do the work.
- Start by drilling a pilot hole with a small bit (e.g., 2–3 mm (0.08–0.12 inches)) then enlarge it to the required size with the final bit.
- Make sure the drill bit is positioned perpendicular to the surface so the handle fits straight.
If you don’t have a DIY background, using a drilling template is also helpful to ensure proper spacing and straight holes.
This way, the doors remain stable, and you can easily install new handles.
